Rear arm toe in
Re: Rear arm toe in
None. All the electrics (Bandit, Rustler, Stampede) have zero rear toe with the exception of the Slash, which uses nitro rear arms.
Re: Rear arm toe in
I really hate to be the one that argues with someone that knows more than me but there definatley is toe in built into the rear arms. I will get some pics tonight. The main thing is I dont know how much.
Nick
Nick
- klavy69
- Moderator
- Has thanked: 639 times
- Been thanked: 294 times
Re: Rear arm toe in
everything I've known and read is backing up harry697 on this one. Get some pix and we'll discuss
Re: Rear arm toe in
Now that I think about it, the Bandit uses different rear arms than the trucks. The Bandit arms are part #2750R. The TRX-1 and TRX-3 used 2750 arms and they have some toe. Not sure if there's anything different between the 2750 and 2750R though.cautrell05 wrote:I really hate to be the one that argues with someone that knows more than me but there definatley is toe in built into the rear arms. I will get some pics tonight. The main thing is I dont know how much.
Nick
Here's a pic I was looking at and that car doesn't appear to have anywhere near as much as my TRX-1. Maybe a little bit.
http://traxxas.com/products/models/electric/2407banditVXL-gallery
Re: Rear arm toe in
I always thought the rear toe was accomplished with different rear hubs on the traxxas cars....
- Lonestar
- Has thanked: 623 times
- Been thanked: 171 times
Re: Rear arm toe in
toe can be in
- arms mount
- arms
- hubs
I doubt there's any car in the trx lineup that has zero toe total... some cars might have some in either/or of the above 3
The "R" parts in traxxas nomenclature stand for "revised" I believe... typically black plastics
Paul
- arms mount
- arms
- hubs
Paul
- Mad Racer
Re: Rear arm toe in
All of road buggys have toe in at the rear in some way,
As Lonestar mentioned . Either in the Arms, Rear hinge pin, or in the hub carriers. Even 1dg makes a big difference .
I bought some alloy rear hubs for one of my off road buggies and i couldn't get any traction in the back at all. It was un drivable totally .. Changed back to the stock hubs and was a different buggy .
The alloy hubs were for the on road version.
In board toe in is better on rough tracks. A trick I learnt while racing on the rough grass tracks in U.K.
Re: Rear arm toe in
I know for sure that the electric Rustler and Stampede have no rear toe-in. A lot of guys running them use the 4-tec carriers to gain 1.5 in the rear, but the stock setup is at zero. The Bandit is most likely 3 degree of toe with the 2750 arms (at least that's what Traxxas used to claim the arms were).
As for the "R", it stands for race (go figure
). I'm still not certain of what exactly the difference is, but it is more than likely just an extra shock mounting position. That was the only difference I saw between the 1931 front arms on the Blue Eagle versus the 1931R arms used on the LS. Dimensions were the same, only difference was the R arms had 4 shock mounting options where the standard arms had 3.
cautrell05, can you confirm how many shock mounting holes are on your Bandit arms please? I have a new set of standard 2750 arms that I just picked up and they have 3 holes.
- SRTracer121
Re: Rear arm toe in
the black bandit arms have 3, atleast the set in my possession does
there is in fact a manufacturer dumb enough to use zero degrees of toe in on their 2wd offroad cars. that mfg is traxxas
- Mad Racer
Re: Rear arm toe in
So let me get this right.
It has no rear toe in a off road buggy, BUT they use rear toe in on a on road car.
Is that right. ???? If this is correct than the Traxxas engineers must have been out on the piss the night before
as they really should have it the other way round.
- SRTracer121
Re: Rear arm toe in
well the pede and rusty have none. the nitro rusty is basically a SRT and the slash uses n-rusty arms as well.
the srt was the last 2wd traxxas made with rear tow and anti-squat.
maybe the trx guys know something the rest of the rc world does not.
Re: Rear arm toe in
From me-
Could you tell me how much toe in is built into the rear suspension
arms of the Bandit?
Thanks
Nick Cautrell
Their response-
Hello Nick,
There is no toe in built into the Bandit rear suspension arms.
Seasons greetings from the team at Traxxas!
Steve Lindholm,
Traxxas Customer Service
Me-
Yes actually there is. However nobody seems to know how much.
[IMG] http://i148.photobucket.com/albums/s19/cautrell05/RC10%20buggy/DCP_7619.jpg[/IMG ]
http://s148.photobucket.com/albums/s19/cautrell05/RC10%20buggy/?action=view¤t=DCP_7619.jpg
Thanks
Nick
Them-
Hello Nick,
I asked our Engineers and they say there is not. I do not have a different answer for you.
regards,
Steve
Re: Rear arm toe in
Mad Racer wrote:So let me get this right.
I get a little confused when you say buggy
SRTracer121 wrote:the srt was the last 2wd traxxas made with rear tow and anti-squat.
Well, adjustable squat at least. All the newer 2.72 transmissions that have the arm mounts built-in have 1.5 of anti-squat.
cautrell05 wrote:What more can I say?
From me-
arms of the Bandit?
Thanks
Nick Cautrell
Their response-
Hello Nick,
Steve Lindholm,
Me-
Thanks
Nick
Them-
Hello Nick,
regards,
Steve
Can't really say I'm surprised at that response.
- 1357 Views
Last post by rnoswal3434
- 577 Views
- 997 Views
Last post by Asso_man!
- 1230 Views
Last post by peetbee
- 592 Views
- 20 Replies
- 3174 Views
Last post by LurkingCAT
- 1929 Views
Last post by xxxmain
- 1009 Views
Last post by slotcarrod
