Rear toe
- esaresky75
Rear toe
On the B4, rear toe is set to 3 degrees with part #9571 (anti-squat is adj. with shims), does anyone make 2 or 1 degree arm mounts? I can't find any info.
Burn more coal - UnderGroundMiners.com
Re: Rear toe
I would have to look, bit I am pretty sure my 4.1 kit came with several different toe/ arm mounts. -Jeff
- esaresky75
Re: Rear toe
Correct, the 4.1 comes with four different mounts for toe but it's a different design. I don't believe they are interchangeable. The B44.1 also is adjustable but another design. Why must they keep redesigning everthing!
- THEYTOOKMYTHUMB
- Has thanked: 3709 times
- Been thanked: 1980 times
Re: Rear toe
So you have to keep buying new!esaresky75 wrote:Why must they keep redesigning everthing!
- esaresky75
Re: Rear toe
I already knew that, I wanted a realistic answer.THEYTOOKMYTHUMB wrote:So you have to keep buying new!esaresky75 wrote:Why must they keep redesigning everthing!
Re: Rear toe
I thought the old and new mounts were interchangeable between the 4 and 4.1 series? I was under the impression that the newer 7487 toe mounts just had the small cutout for the ballast weight added, but were otherwise the same as far as mounting them to the chassis(?)
- Has thanked: 7 times
- Been thanked: 42 times
Re: Rear toe
The new mounts will bolt up to your older B4, 100% sure on that. No need for anything else new other than the mount set.
- esaresky75
Re: Rear toe
B4 Arm Mount part # 9571
B4.1 Arm Mount part # 7487
B44.1 Arm Mount part # 9726
I did find one hobby site that list part # 7487 fitting B4, B4.1, T4, T4.1, SC10
Re: Rear toe
#7487 will fit both B4 and B4.1
and they come in 2.5°, 3°, 3.5°, 4°
As far as I am aware no one does different toe in suspension arm mounts for the B44/B44.1
- 1007 Views
Last post by Asso_man!
- 594 Views
- 583 Views
- 20 Replies
- 3185 Views
Last post by LurkingCAT
- 1945 Views
Last post by xxxmain
- 4987 Views
Last post by SRTracer121
- 624 Views
Last post by Group B
- 1015 Views
Last post by slotcarrod
Users browsing this forum: BIGDADDYBUILDER and 4 guests
