Jelly beans and tires
- radioactivity
- Has thanked: 384 times
- Been thanked: 618 times
For a vintage RC10 that I could run or even shelf, I think that the Jconcepts Rips and Double Dees look like a good alternative.
The Hazard wheels are fairly ugly in my opinion, so not for me.
I've got a couple sets of jelly beans and I don't want to glue them.
The original wheels inserts don't fit the Jconcepts tires.
So I am curious.
Could a 3d printed "Jconcepts tire to jelly bean wheels adapter things" be an answer or even feasible?
Or am I alone in thinking this could be a solution?
Chuck
So I am curious.
Chuck
- Has thanked: 2759 times
- Been thanked: 2250 times
Re: Jelly beans and tires
Is it just the inserted bead lock ring that does not fit the jconcepts tire?
- juicedcoupe
- Has thanked: 268 times
- Been thanked: 2094 times
Tamiya Hornet rears fit and there are several different fronts on Ebay.
- radioactivity
Thanks for weighing in Dadio.
I have gotten a rear Double Dees with the original AE inner ring to somewhat fit.
The ring is really tight at the tire/wheel bead area. Lubricating with WD40 helped.
The other problem is the flat smooth outer surface of the ring allows a foam insert to wander all over the place.
Also an inner ring, an integral part of the larger ring, of smaller diameter to locate outer portion might help.
Yeah I know this sounds a bit confusing. I'll see if I can do some sort of mock up.
Chuck
- radioactivity
Starting with the rears...
The inner ring would locate the adapter on the wheel.
The outer ridges should keep the foam inserts from moving side to side. Foams might need to be sectioned for smaller diameter rims.
Really just trying to establish if these may be feasible or even interesting.
Too thin for printing? What would be the minimum thickness? Suggested material?
Just a concept so far.
Not sure how to share an .skp file and new to sketch up so bear with me
Chuck
Chuck
Looking at the picture if I had measurements I could print it easy enough , might be a bit trial and error to get right .
- 740 Views
Last post by cl76
- 2237 Views
Last post by hugger19
- 2314 Views
Last post by JosephS
- 1938 Views
Last post by tommykart
- 64 Replies
- 7337 Views
Last post by 59burst
- 24 Replies
- 2666 Views
Last post by rc10johnny
- 4198 Views
Last post by XLR8
- 1511 Views
Last post by Frankentruck
Users browsing this forum: tgfarrell and 5 guests
