wiring brushed motor
Forum rules
Biz73
Has thanked: 43 times
Been thanked: 21 times
Post by Biz73 »
I just got a cheap Surpass 17t motor & 60a esc combo for my Ultima. The motor wires are not attached and I want to make sure I set them up so the blue wire on the motor connects to the blue wire on the esc. I know where to connect them, just not sure which side gets which color.
Image20210112_111323 by Justin B, on Flickr
Image20210112_111509 by Justin B, on Flickr
Do I connect the blue wire to the spring side or the heat sink side? I know I can just switch wires if it runs in reverse, but I'd like the colors to match up.
Thanks for your help
Been thanked: 3917 times
Re: wiring brushed motor
blue would be negative and yellow is positive. Doesn’t matter which side of the endbell you go to- can be offset or both at the top or bottom.
Biz73
Post by Biz73 »
Thanks. I didn't notice the + sign on the plastic part of the end bell. I was looking at the copper sides for some kind of markings :lol:
Has thanked: 269 times
Been thanked: 2094 times
Use the tabs on the end to solder too. They give you plenty of surface to connect too.
They are also handy for capacitors.
Biz73
Post by Biz73 »
If I had just seen the + on the end I would have been good. After I saw it I felt like an idiot for coming on here and asking :roll: Now to get it wired up and installed. I've had this Ultima for months and it hasn't had a first run.
