Brushed motor rehab
- juicedcoupe
- Has thanked: 269 times
- Been thanked: 2094 times
Brushed motor rehab
I'm throwing this together at the request of another member. This is just some of the stuff that I do, so take it for what it is. If someone has any ideas to add, please do so.
I rummaged through my stuff and found this crusty Peak Racing 12X2. It looks like a good candidate.
Start by disassembling everything. This one has removable brush hoods, so more detailed work can be done.
Holding the brush hoods with smooth jaws needle nose pliers, I use a mini torch and brass brush to remove any solder. In this case, I also removed the soldered on brushes as well.
Then everything gets a good scrub with dish soap and a toothbrush. A ultrasonic would work as well.
I then remove the decal and prep the can for paint, if necessary. The decals can sometimes be troublesome, this one required acetone to remove all the adhesive. It then got scuffed with a fine sanding block (foam).
If the can is chrome, I'll just try to clean it up. If necessary, I'll buff it with a fine sanding block.
This is the paint I use, Krylon Fusion. It isn't ultra high temperature paint but it bonds well. If you think that you need high temperature paint, consider engine enamel.
I put tape through the mounting holes and bearing, and stuff the can with a paper towel. Then, 2-3 light coats. Give it at least an hour to dry.
While the paint is drying, I reassemble the endbell. If you have the tools, now is the time to align the brush hoods.
This comm didn't need to be cut. It cleared up nicely with a comm stick and fiberglass pen. I'll pick back up with reassembly later.
- juicedcoupe
Re: Brushed motor rehab
Somehow I skipped a step. There must be too many images because it wouldn't let me add more.
After painting the can, before reassembling the endbell, I polished the brush hoods. I used a rotary tool with a nylon brush wheel, with Brasso.
- RC4X4
- Has thanked: 44 times
- Been thanked: 38 times
I believe you can get can decals from MCi, not positive it was them but regardless, very nice work, I have a ton of brushed motors and a cobra lathe, lets just say I need to get to work myself.......
- juicedcoupe
Yes, I have a few laying around. Most of these are from MCI.
- RC4X4
Those are awesome!!!!!!juicedcoupe wrote: ↑Sat Apr 16, 2022 3:51 pmYes, I have a few laying around. Most of these are from MCI.
- juicedcoupe
While waiting for the paint to dry, I decided to rehab the brushes as well. I was just going to put new ones on but these were in good condition and it goes with the thread.
I crimped and soldered new terminals on. These are #4 hole, 18-22 gauge, from ebay.
I then took one of my brush cutters and trued the faces.
- juicedcoupe
They vary in price. I think ~$4-6 each.
They seem to be about the same as some of my thinner originals. Definitely not as thick as an older paper based decal.
- juicedcoupe
Got it back together.
Whoever was in this motor before, had the armature endplay way too tight. I adjusted the endplay and centered the armature in the magnetic field.
I reassembled it with new Trinity springs and the old brushes.
I checked rotation before installing the decal, so that everything would line up like I wanted.
Since this decal has timing marks, I also verified the timing location before installing it.
I don't think it turned out too bad.
- MarkyDents
- Has thanked: 1809 times
- Been thanked: 643 times
Looks phenomenal, well worth the effort
Hey Cru ! Go balls out
- GeneralZod
- Has thanked: 150 times
- Been thanked: 162 times
Results look factory fresh! Outstanding work! I enjoy fixing up my old brushed motors as well. Though, I think I have too many
- Lavigna
- Has thanked: 1099 times
- Been thanked: 1418 times
Great result. Thanks.
- Has thanked: 1243 times
- Been thanked: 639 times
Do you have any guide on the fixed timing motors? I have one of the blue label yokomo stock motors that I'm interested in getting in good running condition.
How much special equipment is needed?
- juicedcoupe
It really depends on the motor and what tools you have access to.
By blue label, do you mean the RC10 kit motor?
- 1324 Views
Last post by knixdad
- 2568 Views
Last post by THUNDERSTRIKE1
- 2185 Views
Last post by Biz73
- 6808 Views
Last post by RC10superfan
- 2673 Views
Last post by tamiya
- 1281 Views
Last post by coxbros1
- 1476 Views
Last post by mycrors4
- 21 Replies
- 2809 Views
Last post by Lonestar
