Brushed motor dyno
- integra22t
Brushed motor dyno
Back in the 90s I used to have a motor dyno that I would like to find again.
From what I can remember it was about 6x9x2 in size. Two sweep needles One for amps and one for rpm. The motor sat facing into the box and was held with 3 finger screws. The motor had a magnetic cam on the shaft. One of the reasons the motors face was facing in. It had a knob to adjust rpm, and it was black with a silver face.
I've done some searches but cant find the right one, and not knowing who made it doesn't help.
thanks
thanks
- Has thanked: 1129 times
- Been thanked: 3918 times
Re: Brushed motor dyno
Yes, by your description I think V10 got it- the Shinwa Motor Dresser
- Attachments
- image.jpg (23.57 KiB) Viewed 5378 times
- integra22t
just seen that one the other day and its nice looking but not quite the one i use to have .. one too many gauges and a little long ... but close .. why did i never take picts of my rcstuff grrrr
The only other one I can think of was the Aristocraft Motor Conditioner, it was very similar to the Shinwa though. Probably made by them
- Attachments
- image.jpg (14.37 KiB) Viewed 5348 times
- integra22t
ya they look realy close .. if i cant find one ill have to pick one of these up
- spru
- Been thanked: 4 times
Hi integra22t,
here is your chance to get a Shinwa motor dresser.
Greetings
Raimund
http://www.ebay.com/itm/Uncommon-SHINWA-RACING-Motor-Dresser-w-Tachometer-Timing-Point-etc-JAPAN-/141296880823?pt=Radio_Control_Parts_Accessories&hash=item20e5f34cb7
Greetings
Raimund
The three screws, sounds very familiar but I can't recall the maker. Build your own, it's not that hard. I got one from Deiter and copied it and made several more. All components from radio crack. Basically you have one motor driving your "test" motor. The drive motor is wired for amp draw and the "test" motor is wired for voltage (rpm). You can put in a couple different resistors to "load" the motor as well. That dyno is one of the few things I wish I had kept.
- integra22t
thanks spru but shipping is more than the item lol
i miss mine too ASC6000 .. when i had it i wanted a diffrent one with a slave motor so i could get my tork curve .. but i did quite well with the one i had
Heads up....
There's a Shinwa on eBay, ending in just under 5 hours. Currently at $35 ($10 shipping).
Item 231283997889.
(I don't know the seller).
I'm a noob, any advantage to this type of dyno over running the motor under water?
Item 231283997889.
- integra22t
thanks for the heads up .. it whent for 75+ 35 to ship to me
the idea behing it is to test and tune brushed motors .. water is a great break in and have done it for years
- terry.sc
- Has thanked: 7 times
- Been thanked: 157 times
Running under water will bed in the brushes faster, but that's all it does.twinrider1 wrote:I'm a noob, any advantage to this type of dyno over running the motor under water?
A Shinwa Motor Dresser will let you tune the motor, so you can see the effect of different brushes and springs, and adjusting motor timing. The numbers on the meters shouldn't be assumed as accurate, but they do give you a good comparison between different motors and different settings on a motor.
Thanks for the information. Glad you got it Integra. I know I ask a lot of noob questions, so I try to help out when I can.
- integra22t
i didnt get it .. the thing was done by the time i saw it
still keeping an eye out
Sorry to redirect this thread, I found my old motor dresser in the loft, which might be the one you used to have.
Like this
https://share.icloud.com/photos/05N0S9_JOcBjRILG_28hifX7Q
I’d sell it if your interested. I realise this is a really old thread now though!
Pm me if interested
Like this
Pm me if interested
- 124 Replies
- 15585 Views
Last post by Dadio
- 2102 Views
Last post by Frankentruck
- 1116 Views
Last post by Lastplace
- 1592 Views
Last post by juicedcoupe
- 2568 Views
Last post by THUNDERSTRIKE1
- 2674 Views
Last post by tamiya
- 967 Views
Last post by harry697
- 21 Replies
- 2167 Views
Last post by Dangeruss
