Hi,
I just found these parts and I would like to know if these parts from Andy's only fits the Yokomo YZ10 or another car too?
Also how do you distinguish if they are the long or the short version?
Thanks to all from Canada.
frenchboomer
Andy's front C hubs
- Regular Member
Re: Andy's front C hubs
the front spindles can possibly be used on the front end of a kyosho 4wd, javelin/optima, they are very similar.
the c-hubs as well, except the kyosho usually bolts the shocks to the c-hub somewhere. those aluminum with bearings are made by an aftermarket company, but there are several and they look similar. maybe cross, kose, someone else.
the andys arms pretty much fit yokomo 870c but would fit any yz10 also, just may be too short. they use the same bulkheads and so would actually attach.
- Regular Member
OK Thanks for the info.
I got all that with the YZ10 I bought
Thanks again,
Christian
Thanks again,
Christian
- 2144 Views
Last post by al.48
- 1062 Views
Last post by dinglem
- 2643 Views
Last post by Ronbo
- 762 Views
Last post by rangerg
- 1522 Views
Last post by USA-1
- 1545 Views
- 821 Views
Last post by juicedcoupe
- 912 Views
