Andy's Front Arms on Ultima
I got a pair of used Andy's A Arms for the front of my Turbo Ultima. Right now I have the stabilizer set on the front, I assume this needs to come off if I go with the Andy's arms. What about the adjustable tie rods? They will be short, correct? What kind would work? Thanks for the help.
- Brandon G
Re: Andy's Front Arms on Ultima
Yes, you are correct, there is no provision for sway bars in the andy's arms. I'm sure with a dremel and a drill you could make it work, but they are not really necessary. The andy's arms add about 1/2" to the width of the front, so you will need to get longer turnbuckles. I did this setup on my vonats Ultima and simply used lunsford tb's with the stock ball ends to get the job done. I can get a measurement of the length you need later on tonite if you like.
- 1555 Views
- 1639 Views
Last post by Badmuthatrucker
- 1211 Views
Last post by juicedcoupe
- 813 Views
Last post by Asso_man!
- 1107 Views
Last post by License2iLL
- 2619 Views
Last post by jcwrks
- 561 Views
Last post by shane
- 1538 Views
