Rear Hubs
- Been thanked: 4 times
Rear Hubs
I have the old classic rear hubs. I went to the track and broke one side of them. I pulled the ball stud out. So are there any options for modernizing? I looked up some information on the site, but all the links are old. All the items to update them are discontinued. Is there a new set of parts for modernizing the rear hubs and dog bones?
Evolving RC10 from 1985, Original Owner!!
- juicedcoupe
- Has thanked: 269 times
- Been thanked: 2094 times
Re: Rear Hubs
These were recently discontinued but still available.
https://www.amazon.com/Team-Associated-7367-Carrier-1-5-Degree/dp/B0006O3C46
They use unflanged bearings, like the 10T.
Re: Rear Hubs
So do I need new spindles and dog bones or do the original fit in there? I am ok with getting the new stuff just need to know what will fit. Thanks very mucn.juicedcoupe wrote: ↑Thu Jul 21, 2022 6:23 pm These were recently discontinued but still available.
- juicedcoupe
Re: Rear Hubs
The originals fit. You just need the correct bearings.rfulcher wrote: ↑Thu Jul 21, 2022 8:34 pmSo do I need new spindles and dog bones or do the original fit in there? I am ok with getting the new stuff just need to know what will fit. Thanks very mucn.juicedcoupe wrote: ↑Thu Jul 21, 2022 6:23 pm These were recently discontinued but still available.
- Has thanked: 1243 times
- Been thanked: 639 times
Re: Rear Hubs
Getting new hubs is a good idea, but you may be able to salvage the hub you have. If the only problem was the ball stud ripping out. The hole can filled with epoxy. When the epoxy is cured drill a new hole and use washers on both side of the stud then use a nylon locking nut on the end. The washers and the nylon nut should take most of the force.rfulcher wrote: ↑Thu Jul 21, 2022 5:25 pm I have the old classic rear hubs. I went to the track and broke one side of them. I pulled the ball stud out. So are there any options for modernizing? I looked up some information on the site, but all the links are old. All the items to update them are discontinued. Is there a new set of parts for modernizing the rear hubs and dog bones?
Re: Rear Hubs
Ok I can try that, do you have a suggestion on epoxy? I also was looking to upgrade the links and change out the ball end with something different.JosephS wrote: ↑Fri Jul 22, 2022 12:08 amGetting new hubs is a good idea, but you may be able to salvage the hub you have. If the only problem was the ball stud ripping out. The hole can filled with epoxy. When the epoxy is cured drill a new hole and use washers on both side of the stud then use a nylon locking nut on the end. The washers and the nylon nut should take most of the force.rfulcher wrote: ↑Thu Jul 21, 2022 5:25 pm I have the old classic rear hubs. I went to the track and broke one side of them. I pulled the ball stud out. So are there any options for modernizing? I looked up some information on the site, but all the links are old. All the items to update them are discontinued. Is there a new set of parts for modernizing the rear hubs and dog bones?
Re: Rear Hubs
JB weld is usually recommended here. I have been using the jb weld epoxy putty to fill holes in my rc things.
J-B Weld Reinforced Epoxy Putty Stick.
If you want to upgrade the links lunsford racing https://lunsfordracing.com/makes well priced sets. Which rc10 do you have?
I'm a fan of the ball and cup ends the car came with. RPM makes a set of replacement rod ends that can work for most of the car.
RPM Heavy Duty 4-40 Rod Ends (White) (12) RPM73381
If you want captured ends dynotech-racing has a set that should work https://dynotech-racing.com/partDetail.php?RefNum=8800
- juicedcoupe
Re: Rear Hubs
I use these ends on the rear of most of my stuff.
https://www.amainhobbies.com/traxxas-long-and-short-rod-and-ball-ends-tra1942/p2815
They are too bulky to use in the front. But in the rear, they are tough as nails.
Re: Rear Hubs
WOW thanks very much guys. I have to be honest I have always HATED the ball cups ever since I built this when I was 13 years old!!! This is an original RC10 classic. The only thing different in the back end is I have some RPM a arms.
I will review all this and see which direction I want to go!!!
Re: Rear Hubs
Good afternoon. I recently bid on some parts for my RC10 ($50 shipped!!!). They came, and I was able to install the below Hubs and CVs. I have no idea what they would have been from. They fit really well, just a little play that I put some shims in for. Does anyone know what version of RC10 they might have come from? (Maybe the one suggested on this thread?)
Re: Rear Hubs
There were quite a number of rc10's that could have been from. Associated issued a kit at one point that used those hubs and axles for converting an older rc10 to 3/16" axles. I have one of those sets.rfulcher wrote: ↑Fri Aug 05, 2022 2:33 pm Good afternoon. I recently bid on some parts for my RC10 ($50 shipped!!!). They came, and I was able to install the below Hubs and CVs. I have no idea what they would have been from. They fit really well, just a little play that I put some shims in for. Does anyone know what version of RC10 they might have come from? (Maybe the one suggested on this thread?)
It was also used in the rc10DS, GT and some models of the rc10t. The hubs were used on the re-release version of the rc10. The 3/16 dogbone stub axles were used on the rc10t2&3 sport and some models of the rc10 (b/t) 4(.0)
- juicedcoupe
Re: Rear Hubs
The carriers were used on the Worlds car, 10T, GT, and T2.
- 3786 Views
- 1215 Views
Last post by chophead69
- 1329 Views
Last post by sbcnyc
- 1428 Views
Last post by JK Racing
- 1039 Views
- 1018 Views
- 1271 Views
Last post by slotcarrod
- 825 Views
Last post by foots
