Front C hubs for 870c build- zc-413
Splat!
Post by Splat! »
So I am trying to restore my first 870c. I found a super clean car that just has a broken front C hub. Looks like I need ZC-413. All other 413 variants look to be incorrect as the lower hinge pin goes through the outer end of the "c" hub instead of the inner. So, Are these SUPER rare? I've been searching the bay for a set but all they have are newer variants. Or is there any other even temporary c hub that will fit until I can find the real deal?
Thanks a ton,
Chuck
TEAM LOSI/TRINITY
SPLAT! GRAPHICS
Re: Front C hubs for 870c build- zc-413
they are different compared to the touring car type, where the hinge pin is on the outer edge.
They are frequently on ebay but you need to keep your eyes peeled. I also believe a kyosho optima part can be substituted(as well as the spindle fyr), and there are some other manufacturers of optima type cars that offer alloy ones. unfortunately, I don't know much more than that.
crusaderlyf
Post by crusaderlyf »
just show your broken parts may be someone have
Splat!
Post by Splat! »
Thanks for the advice! I am seeing that Kyosho OT-55 hubs look like they have the same hinge point. That should do until I can find some actual Yokomo hubs.
TEAM LOSI/TRINITY
SPLAT! GRAPHICS
crusaderlyf
Do you mean this?
Splat!
Post by Splat! »
Those are them!!!!
TEAM LOSI/TRINITY
SPLAT! GRAPHICS
59burst
Post by 59burst »
notorious and lazy pargu is making the C hubs along with some yokomo parts. maybe it's not good for the fragile 870C arms. but useful for the shelfers
Splat!
Post by Splat! »
Thanks for the help guys! Will post pics of my build soon!
TEAM LOSI/TRINITY
SPLAT! GRAPHICS
slazzaro
Has thanked: 6 times
Been thanked: 6 times
Post by slazzaro »
Hello all!
I am resurrecting this thread as I am looking for some 870c C front hubs.
I know that Kyosho OT-47 and OT-55 are compatible, but these have 8 and 15 degrees Caster respectively, while the original 870c parts have zero.
So, is there a direct replacement available anywhere?
Please help!
Kyosho Turbo Optima, Optima MID Custom Special, Optima MID Custom Special truck converted
Yokomo YR4 PRO, YZ-870C
Associated TC4, B3 (x2), B4.1 worlds, C4.2, B42, B44, B6.2, B6.2d, B64
Losi XXXT MF2
Tamiya M05
..more in the past, more in the future..
Ronbo
Has thanked: 23 times
Been thanked: 63 times
Post by Ronbo »
Paul Lomas on Facebook, page is 3DRC Vintage Car Running Spares, 3d prints them stock and with more castor. He should be getting me a set of C hubs and front/rear shaft hubs to back up my RPM units I have on my Masami 89. Otherwise, the ebay.
slazzaro
Post by slazzaro »
Thanks Ronbo.
So, you're saying that adding caster angle to the 870c is good? I've never tested it.
If so, then I can get the Kyosho C hubs..
Please confirm... Cheers
Losi XXXT MF2
Tamiya M05
Ronbo
Post by Ronbo »
More castor will allow better turn in. Cliff Letts article in RCCA in Dec 1990 shows the blocks used.
Return to “Yokomo Forum”
Users browsing this forum: No User AvatarGoogle Adsense [Bot] and 2 guests
