Optima steering link (sc-89) substitute?
Greetings,
My Optima is missing the right side steering link. Is there a substitute that I can use instead of the overpriced sc89 package? I realize that these things are pretty common but I'd like to stick with something that I don't have to modify and looks like the original.
Thanks
Thanks
- Has thanked: 1080 times
- Been thanked: 3730 times
Re: Optima steering link (sc-89) substitute?
Don't tell anyone but the rerelease scorpion tie rods are a perfect match
I just ordered a few off eBay. Look for the people parting out scorpions
Thanks for the great tip. Speaking of the scorpion, would the re re shock spring clamps fit on the optima shocks?GoMachV wrote:Don't tell anyone but the rerelease scorpion tie rods are a perfect matchI just ordered a few off eBay. Look for the people parting out scorpions
Yes, the red shock parts are a slightly different color but fit great! I used them on my Stinger
Thanks! Was the rest NIB? Looks very clean.GoMachV wrote:Yes, the red shock parts are a slightly different color but fit great! I used them on my Stinger
Yes built mostly from nip parts. The shocks were re anodized
http://www.rc10talk.com/viewtopic.php?f=30&t=39118
- Been thanked: 325 times
A pair of Lunsford titanium turnbuckles with the same approximate length could probably be had for cheaper than OEM replacements...and would be a much more durable upgrade, plus make adjustments easier.Grunger73 wrote:Greetings,
Thanks
Thanks. I was contemplating going with the Lunsford turnbuckles as they do make life a lot easier but I think I would rather keep the stock look for now. My digital calliper doesn't have a battery at the moment but when I measured the left side rod with a ruler I got about 50mm. To make life simple , I'll just buy the Scorpion re re set since it's already been proven to be compatible. As for the shock clamps, I purchased an alloy set mad by dhawk-racing. The colour looks good on these. Has anyone used these before?Coelacanth wrote:A pair of Lunsford titanium turnbuckles with the same approximate length could probably be had for cheaper than OEM replacements...and would be a much more durable upgrade, plus make adjustments easier.Grunger73 wrote:Greetings,
ThanksI'd need to confirm but I believe the rod length is about 48 - 49 mm...or 1-15/16".
If they're the alloy rings with a hole for a set screw in each, be careful with those. Unless you use nylon set screws, the steel ones will bite into your nice anodized surfaces and make lovely o-shaped pips. I've never been a fan of that design. pargu2000's alloy clamps are more expensive, but they have the same design as the original plastic clamps, using a screw to tighten together the opposite clamp-ends. The screws never touch the surface of the shock bodies.Grunger73 wrote:As for the shock clamps, I purchased an alloy set mad by dhawk-racing. The colour looks good on these. Has anyone used these before?
Aluminum on aluminum will always tend to scratch up the body so try to make your decision once and lock it down
- 892 Views
Last post by HKS_TRD
- 30 Replies
- 3669 Views
Last post by klavy69
- 677 Views
Last post by joel45acp
- 725 Views
Last post by Harrylarry
- 2173 Views
Last post by pottok
- 501 Views
Last post by Snaab9-2
- 1094 Views
Last post by oldschoolrc10
- 3662 Views
Last post by LaserRC10
Users browsing this forum: DotNetDotCom.org [Bot] and 6 guests
