substitute for yoke wing mounts
- 59burst
anyone tried this?
mugen C0901 muffler stay
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=130342475547
- Bormac
- Has thanked: 20 times
- Been thanked: 11 times
Re: substitute for yoke wing mounts
I reckon they would work just fine. Ive made some of my own with some pretty rough tooling in the shed. These are better than what I could make.
i probably got the real deal new in pack if interested pm me
Edited to add
yup got one last one here
Edited to add
Bear in mind the Mugen 1/8 muffler stay uses a 4mm cs screw to mount...you might consider using muffler stays for 1/10 GP cars. They are more the 'correct' size and uses 3mm screws.
- 59burst
show us your jobbormac wrote:I reckon they would work just fine. Ive made some of my own with some pretty rough tooling in the shed. These are better than what I could make.
I googled but couldn't find 1/10 muffler stays. do you have more info?uzzi wrote:Bear in mind the Mugen 1/8 muffler stay uses a 4mm cs screw to mount...you might consider using muffler stays for 1/10 GP cars. They are more the 'correct' size and uses 3mm screws.
Here is what i am talking about,
http://www.amainhobbies.com/product_info.php/cPath/1_25_1424/products_id/166597/n/Kyosho-Muffler-Stay-Holder-Set
You will also find that the wire gauge used is also alot more smaller in diameter than the Mugen version
- 59burst
I just put my order for kyosho muffler stay
I'll update the pics tomorrow
thanks for your help
- 59burst
got kyosho vz086 bags today.
and I noticed I need a tap bit. side holes are just the holes. no screw tap thread in there
- GJW
whats happenin with kyosho these days
bit inconsiderate
get some pics up ha?
Alternatively you could bend the wire at 90 degrees so the wire will come through vertically (if you are mounting it on the rear shock tower). However, if you want it on a 834B (mounted vertically from the chassis) then it will not work of course.
- 59burst
it's natural it dosen't have tap thread on the side holes. it's for holding the piano wiremarui hunter 73 wrote:whats happenin with kyosho these daysbit inconsiderate
nothing wrong with kyosho
yeh, I know it. and it was very easy to make the tap thread. I put inch screw in the wire hole very slowly and got what I need.uzzi wrote:Alternatively you could bend the wire at 90 degrees so the wire will come through vertically (if you are mounting it on the rear shock tower). However, if you want it on a 834B (mounted vertically from the chassis) then it will not work of course.
- phoenix
- Has thanked: 5 times
- Been thanked: 19 times
one question: does anyone know what additional wing mounts masami used on the original 870C he won sydney with? He used the orriginal ones looking backwards from the tower and the added another set attached to the wires to regain height. But it looks like they are different ones (nearly comparable to old cat ones).
- 59burst
any picture?phoenix wrote:one question: does anyone know what additional wing mounts masami used on the original 870C he won sydney with? He used the orriginal ones looking backwards from the tower and the added another set attached to the wires to regain height. But it looks like they are different ones (nearly comparable to old cat ones).
- phoenix
Here we go: http://www.rc10talk.com/viewtopic.php?f=7&t=3833&hilit=masami59burst wrote:any picture?phoenix wrote:one question: does anyone know what additional wing mounts masami used on the original 870C he won sydney with? He used the orriginal ones looking backwards from the tower and the added another set attached to the wires to regain height. But it looks like they are different ones (nearly comparable to old cat ones).
- 858 Views
Last post by slow_jun
- 963 Views
Last post by Boredome
- 2072 Views
Last post by mk-Zero
- 2211 Views
Last post by npdp72
- 655 Views
Last post by upforit365
- 2258 Views
Last post by drbelleville
- 606 Views
Last post by ChisaiKuso
- 1063 Views
