Rc10 rear axle cone washer substitute?
Hello all,
My cone washers are getting a little squished, and they are backordered most places. Before I order from rc10.com or Robobugs, does anyone know of a substitute that fits the stock axles? Thanks.
- Has thanked: 1129 times
- Been thanked: 3919 times
Re: Rc10 rear axle cone washer substitute?
If your using bearings the 1/4 axle shims #6373 are the way to go
http://www.teamassociated.com/parts/details/6373/
Cool, thanks. So I just put enough in to take out the slop? Doesn't rub on the shield?
Nope, that's what they are made for. You can use them to move the axle in and out to keep the universal from popping out of the cup if you are using universals or cv's. with stub axles I usually run 2-3 inside and use as many as needed to take out the play without binding on the outside.
- Regular Member
Since 6373 has been discontinued, I was wondering if anyone can recommend an alternative? (rebuilding an original RC10 Worlds and missing a few shims)
- juicedcoupe
- Has thanked: 269 times
- Been thanked: 2095 times
I use these.oldschoolrc10 wrote: ↑Fri Jul 02, 2021 1:18 am Since 6373 has been discontinued, I was wondering if anyone can recommend an alternative? (rebuilding an original RC10 Worlds and missing a few shims)
https://www.amainhobbies.com/crc-1-4-shim-set-20-cln4732/p-qtqctatq7zxxactz
- Regular Member
- 3787 Views
- 686 Views
Last post by slow_jun
- 30 Replies
- 3712 Views
Last post by klavy69
- 741 Views
Last post by mrlexan
- 300 Views
Last post by Rouki
- 1518 Views
Last post by robyts
- 733 Views
Last post by Harrylarry
- 2326 Views
