Andy's Optima steering knuckles installation issues
Hi all
I have a pair of Andy's steering knuckles I plan to use on a Mid or a Lazer and they have me a little stumped.
Rather than having the lip between the two bearings which locates them, they are smooth meaning you can push a bearing right through. I can't find any info online for how they were intended to be used. The only solution I can see is to use flanged bearings on either side but not sure if the bearings then end up being spaced too far apart, anyone got any ideas or able to help?
- highwayracer
- Been thanked: 6 times
Re: Andy's Optima steering knuckles installation issues
You are correct...you have to use a 5x10 mm flagged bearing. Andy's used the same part for the Yokomo yz10/870c.....which uses this bearing in the stock configuration.
If you compare the width of the stock Kyosho part vs. The Andy's...the Andy's should be a little bit narrower to compensate for the flange.
I hope this helps.
Regards,
Roger
I hope this helps.
Regards,
Roger
Thanks thats a big help
I can see what you mean about them being a bit more narrow to account for the flange
I imagine any 5x10x4 flanged bearing I can find on eBay will be fine or is there a particular one that is best quality, just wondering if even the flanges are equal width on all of them
- highwayracer
Any one should work. I got a generic set (4) from eBay when I installed mine.
If you're not happy with the Andy's....RPM made ones for the Kyosho cars. Those have the lip...so normal bearings can be used and there's a metal thread for the shoulder screws.
I'd like to use them because I have them, they will probably go on the Lazer Tub project and maybe a pair on my Mid SE shelfer, but I also have a pair of genuine Kyosho knuckles I polished and filed the cast marks out of.
Too many parts and projects, not enough time or space!!!
Do you have a link to the rpm ones I can't seem to find them, they sound interesting
- 2340 Views
Last post by Bholzz
- 578 Views
Last post by Mr. ED
- 821 Views
Last post by murphy3428
- 1672 Views
- 727 Views
Last post by Jay Dub
- 446 Views
Last post by XLR8
- 1047 Views
- 1264 Views
