clutch slips to much
Ive tighten the bolt all the down and the clutch still slips. Is it time for a new clutch disk?
OLD SCHOOL!
- Bottom Feeder
- Has thanked: 13 times
- Been thanked: 25 times
Re: clutch slips to much
I did replace the spur gear with one you would insert metal balls into it, but no metal balls installed. Guess I should try a solid spur gear?
OLD SCHOOL!
- Bottom Feeder
Bottom Feeder wrote:Uhh... what transmission is this?
changed the pad, its not that....
OLD SCHOOL!
- Has thanked: 36 times
- Been thanked: 1319 times
- Bottom Feeder
So it's a Stealth and not a six-gear? It shouldn't matter what spur you used as long as it has the proper two inner holes for the mounting screws. Or the screws are too long aren't letting the pad do its job. But you would see/hear that because the screws would be gouging the inner slipper plate.
Unless the slipper pad and plates aren't assembled correctly, I'd say it's the diff that's slipping.
- Bottom Feeder
Replace the diff? Why? No. Maybe clean it and reassemble it exactly per the instructions just for maintenance, but you should still figure out what exactly is slipping first.
Your right... i have couple stealth buggys i run with BL set up and never seen this problem. I placed a new pad, tighten down the clutch and still hear the whinning noise. It moves but just the clutch slips to much... Thanks for your help.
OLD SCHOOL!
tighten it the way down and did a test run... it runs ok/pretty good. so im going to leave it as is....going to take off easy then accelerate easy...
OLD SCHOOL!
- Has thanked: 1129 times
- Been thanked: 3919 times
When you hold both tires and try to turn the spur, the slipper nut should NEVER turn. If it turns you have the diff loose or at least looser than the slipper.
- 4647 Views
Last post by Dirtcar75
- 2001 Views
Last post by tmail56
- 24 Replies
- 3291 Views
Last post by fredswain
- 1024 Views
Last post by Group B
- 1473 Views
Last post by RC10th
- 2501 Views
Last post by yellabelly
- 1358 Views
Last post by THUNDERSTRIKE1
- 1215 Views
Last post by jkelm24
Users browsing this forum: Google Adsense [Bot] and 4 guests
