Help identify this slipper clutch
blown5.0
Post by blown5.0 »
Could someone tell me what slipper clutch this is, I assume it was made by losi by the spur gear, but that is all I know.
Is this a valuable collectors item along with the MIP transmission.
bearrickster
Re: Help identify this slipper clutch
Post by bearrickster »
The whole slipper is a Losi Slipper clutch
LOSI RULES!!
Bearrickster's Rides
y2kgtp
Post by y2kgtp »
It looks like an assortment of newer parts on an older trans....I'd swear that is the same spur that my Speed-T has
blown5.0
Post by blown5.0 »
So was this just a losi slipper conversion for a stealth transmission? The backplate of the slipper (the one closest to the tranny) is a stock stealth piece.
AscotConversion
Has thanked: 43 times
Been thanked: 56 times
Post by AscotConversion »
Weird trans. The outdrives look to be associated, the slipper Losi. Losi did make a top shaft so you could run the Hydra drive on the Stealth, maybe that is part of what you have. The diff case looks to be custom or prototype?? What is on the inside of the case (post a pic)??
it's an mip 2.61 change box for the rc10/10t. it used the associated internals, but came with its own diff and idler gear to get the lower ratio. it most likely has the losi a-3140 hydra drive topshaft for the stealth trans. they just installed the losi slipper on it instead.
blown5.0
Post by blown5.0 »
Thanks for the info scr8p.
Group B
Post by Group B »
I have a new MIP idler and diff gear for this transmission.
Return to “Identifications”
