What slipper clutch???
- Been thanked: 12 times
Re: What slipper clutch???
losi original single pad
losi modern double pad
A&L power clutch
MIP Slipper clutch
Possibly others, but those are the ones I have seen.
A&L power clutch
MIP Slipper clutch
- bearrickster
if you have the slipper shaft you can use any of the modern losi stuff. if you need help with parts PM me I can set you up
Just to add,
you can also use the ff to incorporate modern Slipper to our racers
- Hydra top shaft
- B4 back Plates/ new Losi back plates
- Spurs
- slipper disks.
- losi thrust bearing/washers.
- Losi springs and nuts
i think this was already discussed before ( Mods, if you feel that it is redundant please delete).
- Hydra top shaft
- Spurs
- slipper disks.
― Confucius
― Confucius
ff=following
― Confucius
― Confucius
- YZ-10
I have a Losi LRM with Hydra fittedKV78 wrote:Will the Hydra drive 3120 shaft work?
If you need photos of parts and how they are assembled let me know
Im using a hydra Drive shaft with this set up.KV78 wrote:Will the Hydra drive 3120 shaft work?
this is the Hydra shaft with the hydra.
― Confucius
― Confucius
- YZ-10
Here is my Losi LRM with the LOSA3120 hydradrive slipper shaft and hydradrive setup...
Hey matt,
I dont imagine you as the losi type guy, let me take those away from you ...... I more on think of you as a yoke guy.... Hahahah
― Confucius
― Confucius
- Been thanked: 4 times
When Hydra Drive came out it was highly praised yet Losi didn't continue with it. How good is it really compared to the modern slippers like the B4 and what are the pros and cons of it?
- 4638 Views
Last post by Dirtcar75
- 1669 Views
- 1024 Views
Last post by Group B
- 896 Views
Last post by vintage88
- 1099 Views
Last post by rustler85
- 2500 Views
Last post by yellabelly
- 1190 Views
Last post by swamppy101
- 3343 Views
