GT clutch conversion to GT2
- mAdMan
- Has thanked: 134 times
- Been thanked: 87 times
I would like to attempt to change a GT clutch to a GT2. The GT1 clutch has no springs and as a result always engages and moves the car forward at idle. Just spoke with Don at AE. He gave me part #2312. A new threaded adapter for the short shaft GT that is also threaded on the other end to accept a Allen bolt, also metric and not SAE, so new bearings will have to be used.
THE PROBLEM:
The GT2 clutch bell is ~1/8" wider. This will likely rub on the spur gear of the GT.
SOLUTION:
A new top shaft and v2 slipper upgrade from a GT2. This shaft is longer so the clutch mounts about 1/8" farther out and can even be shimmed out farther. *Make sure to get the right pitch V2 spur gear.
Luckily I have a AE15 from a GT2 complete. I just ordered the shaft. I posted this as it's still fresh in my memory. When the parts come I'll post back on the results.
THE PROBLEM:
SOLUTION:
- klavy69
- Moderator
- Has thanked: 639 times
- Been thanked: 294 times
Re: GT clutch conversion to GT2
or you can just get an MIP 4n1 clutch shoe set for your gt which has a spring around it to pull the shoes back together. Its always been the first add on to any GT I have ever owned. They aren't as littered all over on ebay as they used to be but they can still be found. The part number is #3012 if that helps the search. That reminds me that I need to check for these at my LHS who used to have a ton of these hanging in the case.
- klavy69
- Moderator
I'll stop in tomorrow night after work. Will get back with you if there are any left. Otherwise he had ordered in several orders that backordered and I got tired of waiting and seeing them all over the place elsewhere I had him order in several more times thinkin he wasn't getting his order in and then they all came at once
- mAdMan
I did find one at Pegasus hobbies it's about an hour from me. I may make a trip down there. Klavy if you already got one for me I'll still buy it.romulus22 wrote:I do see them on eBay pretty regularly. Just have to check in every couple days and wait if Todd comes up empty.
- RC10th
- Has thanked: 52 times
- Been thanked: 1548 times
I'd take a MIP 4-n-1 over a GT2 clutch any day. I would ONLY use a GT2 clutch for a pilot shaft engine.
- mAdMan
The MIP is niiiice. I adjusted the idle so low now.RC10th wrote:I'd take a MIP 4-n-1 over a GT2 clutch any day. I would ONLY use a GT2 clutch for a pilot shaft engine.
The weird ringing stopped. I have a feeling it was the bellhousing? Either way she idles nice now and no rattling.
[youtube]t3DUGxj2iXU[/youtube]
http://www.youtube.com/watch?v=t3DUGxj2iXU
Thank you all
- klavy69
- Moderator
Good to see you got the MIP 4n1. LHS only had one out and has a bunch he put away in a box since he figured he'd never sell them in his lifetime. Now to just find them...
- RC10th
Todd, I'd be interested in two 4-n-1's if you come across them. Best clutch ever.
- 2514 Views
Last post by RC10th
- 4629 Views
Last post by Dirtcar75
- 1189 Views
Last post by shodog
- 1640 Views
Last post by Orange
- 1410 Views
Last post by mAdMan
- 829 Views
Last post by MelvinsArmy
- 1575 Views
- 24 Replies
- 3266 Views
Last post by fredswain
