I've been running my early 6 gear CE with the jconcepts wheels/tires, and I'd like to try some modern stuff. I've read the thread about 2.2s, and it seems there is some problem with the b4 upright and b44 cvd combo on the 6 gear, but is there a workaround?
Also, I think losi 22 and b4 hex wheels have the same offset, and are therefore interchangeable, but I'm not sure. It would be great if I swap rear wheels between cars!
Thanks to everyone in advance, this is a great forum!
losi 22 rear wheels on 6 gear
- DMAT
- Been thanked: 4 times
Re: losi 22 rear wheels on 6 gear
jc racing makes wheels that work with the 1/4" axle and fit 2.2" tires.
http://www.jcracingproducts.co.uk/products/
if your wanting to run 12mm hex wheels on the 1/4" axle, you can get these
http://www.pargustore.com/associated-rc10-hex-adapter-for-rc10-1-4-axles.html
I believe the b44 cva is meant to work with the stock rear carrier. someone chime in if im wrong. If not the b2/b3 cvd kit should work since it had a 3/16" axle and is the same length as the stock setup. http://miponline.com/store/mip1198.html
when i used b4 rear carriers on my car, I had to run the b4 cvd but with the rc10 axle on it.
Thanks for the heads up!
I did some more research, and I'm going to use one of the setups from the woin thread with klein arms. That should let me use my 22 buggy wheels on the rc10ce.
For fronts, I'm going to use the same wheels as the world's rerelease.
- 615 Views
Last post by Synergy
- 1220 Views
Last post by Claymore5150
- 29 Replies
- 4759 Views
Last post by hugger19
- 1542 Views
Last post by JK Racing
- 1270 Views
Last post by thecorrupterx
- 658 Views
- 2931 Views
Last post by delsami
- 1358 Views
Last post by scottmac74
Users browsing this forum: Amazon [Bot] and 6 guests
