Customworks rear wheels on the DS.
scottmac74
Post by scottmac74 »
Has anyone tried these wheels on their DS?
http://www3.towerhobbies.com/cgi-bin/wti0001p?&W=001167969&I=CSWC6253&P=K
If so, do you need to use this spacer?
http://www3.towerhobbies.com/cgi-bin/wti0001p?&W=001167969&I=LXNTA0&P=K
Any real world experience would be appreciated. Thanks.
-Scott
III
Re: Customworks rear wheels on the DS.
They are like a B3 offset/pin I think, I have some at home I can measure. I'll try and stick one my DS and see what happens unless someone has a definite answer.
scottmac74
Thanks for the info jwscab.
Also does anyone know the overall length of just the CVD bone (without the axle) for the DS? (MIP #1199).
III
lpddpd
Post by lpddpd »
Looks like 450 mm :wink:
That's a big negative on the customworks wheel on the DS. I didn't measure it, but the wheel crashed into the shock with at least 1/4" more needed to seat the wheel.
scottmac74
lpddpd wrote:Looks like 450 mm :wink:
Thanks lpddpd, that pic is helpful. One thing, isn't 450mm (17.7") is rather long for a CVD bone? :lol:
III
scottmac74
jwscab wrote:That's a big negative on the customworks wheel on the DS. I didn't measure it, but the wheel crashed into the shock with at least 1/4" more needed to seat the wheel.
Thanks jwscab, that 0mm offset is what had me concerned. (Just like trying to put B4 2.2" wheels on my 1990 team car...too much backspacing). Oh well, the search continues... :|
III
lpddpd
Post by lpddpd »
How did that 0 get in there? :oops:
Has thanked: 358 times
Been thanked: 470 times
The CW rims will work on a DS, just need a .200 spacer after the drive pins-
scottmac74
Charlie don't surf wrote:The CW rims will work on a DS, just need a .200 spacer after the drive pins-
Thanks Reg, I just need to sand off 0.025" from each of the CW spacers and double them up. I am going to give that a try and update when I know something. Thanks for all the help guys.
-Scott
III
