Early MIP Transmisson Cleanup
twinrider1
Post by twinrider1 »
The plan is to freshen it up with a good cleaning and new grease.
I've found threads and scans for 4wd and SP1, but just a few pics of this one. Would love to learn more about it, especially the model name, any instruction/ad scans of it, etc. So let the discussion begin!
How it came to me, a real Frankenstein.
twinrider1
Re: Early MIP Transmisson Cleanup
Reserved for during and after pics.
twinrider1
dj_kilroy
Post by dj_kilroy »
That is a really cool car, part srb, part rc 10.
Where did you find it?
It should clean up really nicely.
Cheers
David
shodog
Been thanked: 91 times
Post by shodog »
That ball diff is from Thorp
twinrider1
Thanks Shodog. I'm learning bit by bit. I might have already mentioned this, but you're collection is amazing. So clean. And great pics. I just browse through your pictures and notice something new every time.
DJ Kilroy, I found them at a garage sale just a few blocks from my house. I rarely stop at garage sales, but this one had 5' tall antique wheeled fire extinguisher out front.
ron
Post by ron »
I have the same thing, I mean the white nylon casing from MIP, but it is fashioned to fit the RC10 buggy. The ball diff inside is narrower and is aluminum, at first I thought it was full metal. But it looks like it is in very good condition, I have 2 brass gears. I think it is great you have a nylon gear, it will lower wear and tear in the diff gear and the other brass, its also a fail-safe between the 2.
mk-Zero
Business Member
Has thanked: 4 times
Been thanked: 21 times
Post by mk-Zero »
ron wrote:I have the same thing, I mean the white nylon casing from MIP, but it is fashioned to fit the RC10 buggy. The ball diff inside is narrower and is aluminum, at first I thought it was full metal. But it looks like it is in very good condition, I have 2 brass gears. I think it is great you have a nylon gear, it will lower wear and tear in the diff gear and the other brass, its also a fail-safe between the 2.
Sounds like you've got the same version I do, see the 4th post down here --> http://www.rc10talk.com/viewtopic.php?f=35&t=34009&start=75
Twinrider's is a slightly earlier version than yours and mine, there's some more discussion here --> http://www.rc10talk.com/viewtopic.php?f=35&t=34009&start=90
ron
Post by ron »
OH, YES, that is where I first saw the diff, from your post and I followed the other links from it, Yes, I have the same one as yours except that the gearbox is white, I guess they either changed to white from black or vis-vesa OR made it side by side for preference from the buyer. The thing is these are really cool, I very much like the design of the MIP gearbox casing an I can use to go with a Tamiya SRB like the scorcher, I have the original front arms from the MK 1 scorcher saved up, it has the thin arms.
Phin was selling this diff on ebay a few months back and I INQUIRED, told me it was for the RC10, same size and pitch of the SRB they are selling now, except the axles are shorter AND since I had a few RC10s around, I opened up one and right there, I had the same MIP ball diff!!
I am going to open up the others to see what might be inside
mk-Zero
Business Member
Post by mk-Zero »
Mine was originally white, the pervious owner died it balck.
ron
Post by ron »
Oh, so there were no 2 versions, ha ha ha, that's what I thought initially. Well MIP certainly did a good job at making these, they are really compact in nature, I like the simple rounds of the design.
I have a stealth ball diff as well, well used, I will assemble that and keep as spare. I also have NEW MIP axle ends, bearings but not the aluminum diff gear, good to have.
I am at the moment trying to get my hands on a CRP or thorp ball diff for the kyosho scorpion.
These parts are really cool, they are made well and performance wise, its top notch. Just make sure you have a proper slipper, you don't want the diff to slip as well as create the differential rotation of the wheels :mrgreen:
Return to “Tamiya Forum”
Users browsing this forum: User avatarMelvinsArmy, No User AvatarTbot [Bot] and 3 guests
