Rc10L cleanup
ra272
Been thanked: 7 times
Rc10L cleanup
Post by ra272 »
Hello, I picked up a dusty Rc10L on ebuy.
It came with a novak T4, Sanwa-Airtronics controller, a race pre motor, an horrible Mercedes body, the box and few miscellaneous parts.
Nice T4, I hope it's still working.
I don't think this car ran a lot: a thrust bearing is missing, and the rear axle is not aligned with the pod. :lol:
Sadly, it has probably hit a curb...
First thing to do: fix the graphite chassis.
The worn part is cut out, and a small piece of carbon is cut to fit exactly like a puzzle.
Parts glued together and sanded.
Then the finished repair, with countersunk hole.
Has thanked: 1079 times
Been thanked: 3726 times
Re: Rc10L cleanup
Very nicely repaired! I'm impressed!
ra272
Re: Rc10L cleanup
Post by ra272 »
Thanks.
All the parts have been whitened in an hydrogen peroxide bath under the sun.
Then all aluminium parts have been cleaned and slightly polished.
ChisaiKuso
Has thanked: 5 times
Been thanked: 27 times
Re: Rc10L cleanup
Post by ChisaiKuso »
Wow! I am very impressed by that graphite repair. 8)
Something clever goes here...
ra272
Re: Rc10L cleanup
Post by ra272 »
Thanks, it's even more impressive with the bumper mounted. :lol:
Those cars are really easy to rebuild.
RC10resto
Has thanked: 1439 times
Been thanked: 548 times
Re: Rc10L cleanup
Post by RC10resto »
Well done 8)
Wazza22
Re: Rc10L cleanup
Post by Wazza22 »
Thats beautiful! I love the original 10L more than any other 10th scale pan car. I had one new when they came out and from memory had a reedy gold star motor.
Please post more photos when you can
Cheers
V12
Been thanked: 100 times
Re: Rc10L cleanup
Post by V12 »
Nice repair and project.
The RC10L was my first 1/10 pan car as well, got it upgraded later with the reactive caster front end.
I have no original RC10L left, but a RC10LS and the old front end so could do the L if I ever want to.
ra272
Re: Rc10L cleanup
Post by ra272 »
I really like the simplicity of the 10L. The chassis is cleaned and rebuild, next I have to install electronics.
I will probably keep the Novak T4 if it still works, with a mild brushed motor.
ra272
Re: Rc10L cleanup
Post by ra272 »
Old tires have come off really easily with petrol, and original wheels are still in very good shape.
Only problem is to found fresh tires... :mrgreen:
After a few research, I decided to use 6 front Tamiya F104 tires, with two tires glued on each rear wheels...a little expensive (30$ for 6 tires) and a little stretch (tires are 42mm id, rims are 47mm od), but I'm very happy with the result.
sandkil
Has thanked: 782 times
Been thanked: 585 times
Re: Rc10L cleanup
Post by sandkil »
Just WOW :o
Very nice clean up/resto.
ra272
Re: Rc10L cleanup
Post by ra272 »
Thanks. :)
I rebuild the motor: com cutting, cleaning, bearings oiled and new Peak brushes.
Electronics cleaned and installed as described in the manual. :lol:
ra272
Re: Rc10L cleanup
Post by ra272 »
I cleaned the transmitter, it's not legal to use it in France (75mhz is for radio and tv reporters), but I think it's a really cool looking thing.
The body is too ugly (could have been in the POS challenge), so I bought a new 962 TBG (Andy's repro ?).
Wazza22
Re: Rc10L cleanup
Post by Wazza22 »
ra272,
That looks great. There is something about the simplicity of the first 10L's that always draws me in! I miss mine :|
Cheers
Has thanked: 33 times
Been thanked: 1186 times
Re: Rc10L cleanup
looks good. nice work on the chassis repair, too. :wink:
