DIY 6 cell battery packs: loose NiMh sourcing?
- TRX-1-3
- Has thanked: 2066 times
- Been thanked: 992 times
Howdy,
Anybody got a bead on loose NiMh cells, hell, NiCd's for that matter.....? I'm thinking Dean's battery bars, some 12 ga, shrink wrap and sermos connectors. Right? Yeah. Need to keep the width to fit the battery cups though. Offset "L" tabs for +/-. Keep the wires on top instead of soldered directly to the battery ends. Am I making any sense? Maybe a thread already exists for this?
Hey thanks,
Mark
Hey thanks,
Mark
- tamiya
- Been thanked: 9 times
Re: DIY 6 cell battery packs: loose NiMh sourcing?
Check locally for industrial supplier for loose cells.
Unfortunately nobody commercially matches them anymore these days afaik n
There are a bunch of websites that sell loose cells. I've used battery space.com before. You can the cells with tabs welded on it makes assembly a cake walk with little risk of cell damage.
RC10 Short Arm | Novak Tempest ESC | Tamiya Torque Tuned 25T | Savox 1258 | Stealth Trans w/ Exotek Slipper Eliminator (geared 24/81)
RC10B3 | HW Just Stock Club Spec | Reedy 13.5 | Savox 1258
They don't show them on the web site but I believe I've seen 4 packs of loose sub C cells at harbor freight for like 9 and some change?
- soniccj5
Bought a pack of 15 Nicads for a drill on ebay. I saw some NiMH as well.
- tamiya
btw just a warning that RC-spec nickel cells are built for fast charge
cheap generic cells meant for power tools are usually slow charge (12-15hrs @ 0.1C) only
I have bought blingy goldchrome subCs from Tandy RadioShack before,
packed them up into a neat hump then thought I'd give them a gentle
1A charge.... before long they're hissin' & popping
Does same when trying to drain them under 5mins too
- Been thanked: 10 times
i usually go for stickpacks with that has a clear shinkwraping so that you can se the invidual cells and just break em apart and solder up saddlepacks . as easy as eating pancake ...
mvh isobarik
mvh isobarik
- 3201 Views
Last post by tommy2c
- 925 Views
Last post by esaresky75
- 739 Views
Last post by treehugger
- 1987 Views
Last post by knucklebuster
- 922 Views
Last post by sandkil
- 2362 Views
Last post by minreg
- 2349 Views
Last post by THEYTOOKMYTHUMB
- 1794 Views
Last post by THE H.P FREAK
