Vintage looking Nimh packs that fit RC10
General info, Q&A.
frgna
Post by frgna »
Hi guys
Looking for a vintage looking new pack that will fit the RC10 without mods - I tried a few packs at the LHS but they were too big, I am thinking I probably need to find a 1500 MAH pack or something in that vicinity.
Preference for packs that are assembled all side by side (e.g. batteries sides are all touching) not the 3 and 3 tube style.
Thanks in advance!
rctenracer
Been thanked: 81 times
Re: Vintage looking Nimh packs that fit RC10
Post by rctenracer »
Nothing out there for the side by side packs. Stick packs work if you remove the end caps. Or mount the battery cup forward with servo tape and use the standard stick pack. Why not assemble your own side by side ?
teman
Been thanked: 6 times
Post by teman »
This company sells side by side 6 and 7 cell nimh...
http://www.maxamps.com/MA-5000-6Cell-Flat.htm
I haven't personally bought any, but maybe someone else here has?
-Kevin
teman
Post by teman »
-Kevin
cobalta70
Been thanked: 16 times
Post by cobalta70 »
I noticed recently that HobbyKing now carries a couple of nimh stick packs. See here:
http://www.hobbyking.com/hobbyking/store/__37322__Turnigy_7_2V_3000mAh_High_Power_Series_Ni_MH_Stick_Pack.html
And here:
http://www.hobbyking.com/hobbyking/store/__37321__Turnigy_7_2V_2000mAh_High_Power_Series_Ni_MH_Stick_Pack.html
I have not tried these myself, or looked to closely at the dimensions, but you certainly cannot beat he price.
teman
Post by teman »
You could probably get some large yellow shrink wrap and re-wrap those to look vintage if need be. I'm planning to do the same with some saddle packs for my 12's :wink:
-Kevin
clm
Has thanked: 100 times
Been thanked: 205 times
Post by clm »
I have 4 of the hobby king 3000 packs on the way right now, bought them as they should be decent basher packs for 11.20 a piece... then they add a bit of extra advertising /after/ I buy them lol!
...Send the code below to any of your friends, and if they use the code when adding the item to their cart they will pay only $9.68 plus you will get a refund of $1.52!...
$9.68 for a battery pack... that's cheaper then I was able to find for a decent 1/2a nimh pack for this mini slash of the neighbor!
Crazy
Chris
Mini - T, LST, LST2, Crawler
Micro - Trekker, SCT, T
kink
Post by kink »
I have a Vapextech 5000 Nimh which fits my RC10 with zero mods. No need to cut the battery holders. I removed the sticky product labels easily, so the only graphics left are a red "5000" on a black background. Not stictly vintage looking, but plain and very cool, imo. In fact it is about the only colour on my car.
GARBO 1/8
limestang
Been thanked: 249 times
Post by limestang »
Kink do you have a US source on Vapextech batteries?
Thanks Limestang
8rad
Has thanked: 9 times
Been thanked: 38 times
Post by 8rad »
Thats exactly what I need for my project........
clm
Post by clm »
You know... I think some repro nicad labels would be rather helpful for restorers, relabel a modern battery with an old yellow or red cell label... and not have the vintage run time :)
Chris
kink
Post by kink »
No USA source. I bought mine in the UK, for the UK. If you get stuck I can help re-ship them to you. But I guess postage would be a killer due to the weight.
GARBO 1/8
clm
Post by clm »
Just got my 4 packs in, love the engrish in the warnings.
-Do not disassemale or short circuit battery
-Do not wet and incinerate battery. (Apparently doing one or the other is fine however ;) )
-Do not solder or battery directly Charge battery only with Charger designed for it. (Hmm run-on engrish made up of two or more bullet points squished together... not sure on exact amount!)
Chris
teman
Post by teman »
Here's the shrink I was talking about, not sure what width we'd need but there's plenty to choose from :wink:
http://www.rcdude.com/servlet/the-Connectors-%26-Cables-cln-Heat-Shrink/Categories
-Kevin
8rad
Post by 8rad »
I looked into repro labels a while ago.
Most places that can do printed heat shrink labels want minimum order of a billion.
