CORALLY 1/10 PAN CAR MODEL ???
Jerzi
Post by Jerzi »
I found this car and have few question.
What model is it.
Where there an carbin version if it.
It looks like an 1/10 but for sure this is much more narrow then an associated 10L model.
The car look pretty good shape.
I think I have plans for this car but not sure yet.
I could be easy to make an carbon version of it.
Jerzi
Re: CORALLY 1/10 PAN CAR MODEL ???
Post by Jerzi »
Will place the pic later. For some reason it doesnt work now with the phone :?:
jerzi
DennisM
Has thanked: 30 times
Been thanked: 62 times
Post by DennisM »
If it says Corally on the axle, is made of alloy and a 1/10 pan.
My guess would be SP10 ?
Hope Your plans doesn´t include tarmac :wink:
http://www.flickr.com/photos/71175789@N05/8179939954/
Gone fishing
Jerzi
Post by Jerzi »
The rear looks the same but front is diffrent.
My red arm is in one piece not like in your pic.
jerzi
DennisM
Post by DennisM »
Oh, then Yours must be the last of the Alloys - SP10X.
I know nothing about them, besides having 2 SP10´s now and having a SP12 when I was 16-18 years.
We used to run Schumacher TC´s indoor at winter time. Most of the others had some fast setups, and I was just strolling around with the offroad electronics from the Mid.
When I bought the SP12 I was no longer left behind :lol:
Gone fishing
isobarik
Been thanked: 10 times
Post by isobarik »
Was there more then one alloy sp10 ??? ts funny i have had one of those wierd touring narrow u used to run an bmw m3 touring body on mine. There was also an version where the diemnsions on the car was more right 235 rear and so.
This was 90/91 so .
mvh isobarik
EvolutionRevolution
Has thanked: 17 times
Been thanked: 34 times
Post by EvolutionRevolution »
isobarik wrote:Was there more then one alloy sp10 ??? ts funny i have had one of those wierd touring narrow u used to run an bmw m3 touring body on mine. There was also an version where the diemnsions on the car was more right 235 rear and so.
This was 90/91 so .
mvh isobarik
I thought the only narrow car they did was the CCT? Which would be mid-1990s, together with the C-10.
DennisM
Post by DennisM »
The axle on my SP10 is adjustet down to 230mm between the outer edges of the rims.
Seems like it could be at least 40mm wider.
Gone fishing
EvolutionRevolution
DennisM wrote:The axle on my SP10 is adjustet down to 230mm between the outer edges of the rims.
230-235 mm is the normal (and race-sanctioned) width of a modern Pro-10. A narrow Pro-10 car is 200-210 mm wide. Often the axles allow for wider cars, but good luck finding a decent body for those...
DennisM
Post by DennisM »
Thanks EvolutionRevolution
Here´s a picture of my Corally pan cars.
F1, C10 graphite and SP10
Gone fishing
terry.sc
Has thanked: 7 times
Been thanked: 157 times
Post by terry.sc »
There was two 1/10th Corallys with an alloy chassis, the original SP10 with the two wishbones joined by a thin link, and the SP10X with the trailing arm as seen in DennisMs photo. The SP10X was replaced by the SP10G, virtually the same but with a carbon chassis instead of alloy.
The standard Corally setup was around 210mm wide using Corallys own wheels, although the axle is easily long enough to add spacers on the axle to increase the width. There was also a version of the SP10G running standard pan car wheels, which was 240mm wide called the SP10GN, and a narrow super speedway oval version using pan car wheels around 210mm wide called the SP10GS SS.
JK Racing
Has thanked: 139 times
Been thanked: 246 times
Post by JK Racing »
graphite Corally, dont know what model though.
DennisM
Post by DennisM »
JK -
Yours seems to be a fine example of a SP10V
Gone fishing
DennisM
Post by DennisM »
Seek and You shall find -
Found that I had the CCT in the dungeon :mrgreen:
Gone fishing
rcpitwork
Post by rcpitwork »
JK Racing wrote:graphite Corally, dont know what model though.
this one is SP10V
