RC10B4 WHEELS ON RC10 Gold pan? Do they fit?
General info, Q&A.
cybercrxt
Post by cybercrxt »
As the topic asks, I have a gold pan buggy runner, and need some wheels and tires for it. I like the B4 wheels...Does anyone know if they will fit on correctly? If not, will B2 and B3 wheels fit? Thanks for any help. Mike
templeofspeed
Been thanked: 33 times
Re: RC10B4 WHEELS ON RC10 Gold pan? Do they fit?
Post by templeofspeed »
Read this post http://www.rc10talk.com/viewtopic.php?f=1&t=3177
There are compatibility issues... but they can be overcome.
If you want to run modern 2.2 tires and still use your original 1/4" axles in the rear you need to search for the Losi made RC10 replacement rear wheels. They show up in the BST from time to time. I think mikedealer had some, and I'm pretty sure I can dig some used ones up. Fronts you can use B2/3/4.
cybercrxt
Post by cybercrxt »
Thanks so much for the reply and info. Big help! Mike
matteo
Post by matteo »
I picked up some b4 fronts and seem to rub when at full steering throw. Does a spacer need to be used or a wider front axle to eliminate this problem?
MOmo
Post by MOmo »
templeofspeed
matteo wrote:I picked up some b4 fronts and seem to rub when at full steering throw. Does a spacer need to be used or a wider front axle to eliminate this problem?
Use the Associated 7222 front axles with B4 front wheels:
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXKYT2&P=7
You'll need the 6221 inline steering blocks for these axles.
matteo
Post by matteo »
Another good read:
viewtopic.php?f=35&t=5483
Yeah, this id definately what I'm looking to do. Thanks.
http://www3.towerhobbies.com/cgi-bin/wt ... LXKYT2&P=7
Thanks for the info. It all makes perfect sense now.
