RC10 gold pan front axles & newer 2.2 wheels
vaughan3320
Post by vaughan3320 »
i understand how to convert the rear to 2.2s with 3/16 axles. my question is what do i do in the front do i change bearings in the front to accommodate 2.2 rims or spindles i could use some good advice on this one thank you. :?:
teman
Been thanked: 6 times
Re: RC10 gold pan front axles & newer 2.2 wheels
Post by teman »
I have (what I believe to be) yellow front b4 wheels with the larger outer diameter plain bearings and it fits my gold pan axels fine.
-Kevin
vaughan3320
do you know what size bearing that is is it 3/16x3/8 or 1/4x3/8 any help would be greatly appreciated? :D
teman
Post by teman »
Buy according to your axel diameter and the outer diameter of the axel hole of the wheel. The set I bought at the LHS were custom works bearings to fit the newer wheels and still be able to use the 1/4" axel diameter.
-Kevin
vaughan3320
thanks for the info are the bearings 3/8x1/4 or 3/8x/3/16 thanks? :D
teman
Post by teman »
B4 front wheels use 2 for each wheel - unflanged size 3/16 x 3/8. I tried both old rc10 axel versions and it's fine.
http://www.teamassociated.com/parts/details/3977/
-Kevin
Users browsing this forum: No User AvatarSemrush [Bot] and 7 guests
