RC10 Gold pan jconcepts wheels dont fit
- Has thanked: 4 times
Per a suggestion on this forum I purchased some Jconcepts mono 2.2 rear wheels (JCO3404W), and some Jconcepts JCO3403W rear wheels. Both are pictured. Neither fit out of the box. I realized that I need the 3/16x3/8 bearing for the front, my original bearings are the tapered type and too small. I think the bearings should do the trick on the fronts...
The rear JConcepts wheels appear to have a slightly larger hole for the shaft and do not fit properly on the inside. I might be able to get them to fit if I drill out the center (see pictures). Which rear wheel can I use, or can I make these work?? Please see the amazon photos link for photos: https://www.amazon.com/photos/shared/dRlwaobBR8mcdOPLzeZCKg.ttvFOD0M63DTs8aWPdi4_K
Both shaft sizes are 3/16.
Thanks in advance for any suggestions!!
Re: RC10 Gold pan jconcepts wheels dont fit
I can't see the pictures but it sounds to me that you actually have 1/4" axles on your rc10. The mono wheels are really for b2/b3 and rerelease worlds with 3/16" axles. The 1/4" axles have an 8-32 thread which is slightly less than 3/16", and where the pin is, it tapers up to 1/4" for the bearing. The pin is also a larger pin than for a 3/16" axle.
You have some options but it depends if you have cvds, universals or bones/cups.
- Has thanked: 1243 times
- Been thanked: 639 times
If you pictures are from your car you have the wrong wheels.68lemans462 wrote: ↑Tue Dec 06, 2022 12:44 pm Per a suggestion on this forum I purchased some Jconcepts mono 2.2 rear wheels (JCO3404W), and some Jconcepts JCO3403W rear wheels. Both are pictured. Neither fit out of the box. I realized that I need the 3/16x3/8 bearing for the front, my original bearings are the tapered type and too small. I think the bearings should do the trick on the fronts...
'gold pan' covers an long span of time for rc10's and you have one of the older ones.
This would have 1/4" axles on the rear.
the proper wheel for that is
https://www.jcracingproducts.co.uk/rc10
The fronts would be fine if you change up the bearings as you noted.
As well you can convert the rear to be the 3/16" axles used on the 'newer' rc10's. That would allow you to use the wheels you have, but It's so much simpler to just get the jcracing wheels.
If you are really in a bind you can sort of carefully drill out the wheels you have with a drill bit until they fit, but it's easy to make them off balance or simply take off too much material.
The wheels you have fit the last produced rc10b3, b4 and worlds re-release. Associated also made kits that allow for mounting those wheels.
the 1/4" axles had 3 sizes of wheel and tire that went along.
original 1.7" https://jconcepts.net/hazard-17-rc10-rear-wheel
2.0/2.1" from the team car and the rc10 CE (championship Edition)
2.175/2.2" for the original worlds car
rc10b2 sport and b3 basic and sport also came with 1/4" axles as your car has.
This is just what I needed. Thanks!JosephS wrote: ↑Tue Dec 06, 2022 1:29 pmIf you pictures are from your car you have the wrong wheels.68lemans462 wrote: ↑Tue Dec 06, 2022 12:44 pm Per a suggestion on this forum I purchased some Jconcepts mono 2.2 rear wheels (JCO3404W), and some Jconcepts JCO3403W rear wheels. Both are pictured. Neither fit out of the box. I realized that I need the 3/16x3/8 bearing for the front, my original bearings are the tapered type and too small. I think the bearings should do the trick on the fronts...
- Has thanked: 1129 times
- Been thanked: 3919 times
Jcon should really be a lot more clear about this. They say it fits RC10 however while the offset is correct there was only one RC10 (not b2 etc) that ever came with 3/16 axles- the rerelease worlds car. Every other RC10 was 1/4”. I bet they get some phone calls for this.
- juicedcoupe
- Has thanked: 269 times
- Been thanked: 2094 times
BTW, I looked back at the OP's older thread. JC Racing wheels were suggested there as well.
The other options suggested were the JConcepts Hazzards and using B2 fronts with Traxxas rears (hex).
- Has thanked: 51 times
- Been thanked: 108 times
To be fair, if you're not familliar with both shops, it is easy to get confused with JConcepts and JC Racing.juicedcoupe wrote: ↑Tue Dec 06, 2022 3:29 pm BTW, I looked back at the OP's older thread. JC Racing wheels were suggested there as well.
*** POWDER - KING ***
- Frankentruck
- Has thanked: 2605 times
- Been thanked: 2979 times
I agree, a set of Custom Works 7210 CVDs makes a nice upgrade and they are very affordable. Smooth, less slop than dogbones, readily available, and made by MiP. Just needs 2 pair of FR166ZZ bearings for the axles. Lots to like about CVDs.
- juicedcoupe
Perhaps. I thought I was clear in the original thread but I can see someone getting mixed up.Chewbacca wrote: ↑Thu Dec 08, 2022 8:06 amTo be fair, if you're not familliar with both shops, it is easy to get confused with JConcepts and JC Racing.juicedcoupe wrote: ↑Tue Dec 06, 2022 3:29 pm BTW, I looked back at the OP's older thread. JC Racing wheels were suggested there as well.
- RichieRich
- Has thanked: 39 times
- Been thanked: 25 times
What I've done instead of buying a whole set of 3/16 CVDs is just swap out the 1/4 axle with a 3/16 and reuse the rest of the 1/4 cvd parts.
- 2485 Views
Last post by matteo
- 1828 Views
Last post by juicedcoupe
- 1155 Views
Last post by Hcp22
- 2390 Views
Last post by AzSonicSnake
- 1935 Views
Last post by teman
- 24 Replies
- 4153 Views
- 573 Views
- 1097 Views
Last post by RC10th
DotNetDotCom.org [Bot] and 7 guests
