Determining rollout and gear ratios for 1/12 scale
tommykart
Post by tommykart »
Ok here is the question. What are target ranges for both gear ratio and rollout supposed to be for 1/12 pan cars on small carpet road track? I have looked at some charts and some calculators for the numbers, but what are the target numbers that you look for?
I am running 49mm rear tires with 76 spur and 50 pinon
thanks for all input in advance
Tom
GreenHell
Re: Determining rollout and gear ratios for 1/12 scale
Post by GreenHell »
It depends on the wind of the motor...
My blinky 17.5 car:
Geared 58/76
43mm rear tires
= 103mm roll-out
if your running mod it should be much less. I would reference some of the setup sheets on the AE site for a starting point.
"All I wanted was a Pepsi..."
My Gallery | My Feedback | Rapid_RC
tommykart
Post by tommykart »
I am running the novak club motor and esc 17.5 blinky ok I'll check that out
thanks GreenHell
i checked out some of the set-ups but they might as well been written in greek :P
What does the roll out number tell you?
thanks again
Tom
teman
Been thanked: 6 times
Post by teman »
This document is a good read, pg 2 talks about rollout. It's written more for off-road, but it's still general enough to be applied to 1:1 on-road.
http://www.teamassociated.com/pdf/cars_and_trucks/shared/gear_ratios.pdf
-Kevin
Users browsing this forum: User avatarHalgar and 5 guests
