Gear ratios for a 6 gear brushless
Can anyone give me an approximate gear ratio for an RC10T with a 6 gear tranny and a novak brushless? I am not sure what I am running now but my 6 cell battery is getting hot on every run, hot enough to melt the outer cover off. I appreciate any help.
Re: Gear ratios for a 6 gear brushless
Which Novak brushless motor? I’m guessing you have a fairly fast one, and it’s trying to pull more amps than you 6 cell can provide. What battery, age, etc? Might need a better battery, even with gearing changes (or a motor change). Oh, and how freely does the 6 gear run?
The battery is brand new. 5300mah I believe. The 6 gear turns smoothly.
OK, still need to know which brushless motor it is. This is critical to gearing.
Oh, and a general description of use and running surface can help.
The motor is a Novak Velociti 5.5r. I mostly run in on pavement and grass.
- Lonestar
- Has thanked: 623 times
- Been thanked: 171 times
there hasn't been any development on nimh for ages now. A 5.5 is a seriously hairy mill that pulls A LOT of amps... what I'm saying is that the technology of "leisure" packs like yours isn't matched to that motor. What you're seeing is the internal resistance of the pack being too high, and generating too much heat under the high load (current) of the 5.5.stone7223 wrote:The battery is brand new. 5300mah I believe. The 6 gear turns smoothly.
More than going to more conservative gearing, get a better battery or a milder mill (10.5's is plenty plenty plenty enough for a 6G)
Paul
- 3525 Views
Last post by teman
- 1129 Views
Last post by JK Racing
- 3834 Views
Last post by Russ Winn
- 1056 Views
Last post by joel45acp
- 4501 Views
Last post by Hcp22
- 21 Replies
- 2047 Views
Last post by longboardnj
- 1189 Views
Last post by pumpkinfish
- 1283 Views
Last post by pcrussell50
