Transmission Internal Drive Ratios
- Eau Rouge
- Been thanked: 5 times
Lots of people are running their vintage cars more and more, and using contemporary electronics in them on the track. Gearing is always an issue for many newbies and vets, alike. To get a proper gear ratio for your motor, battery, tire and chassis, it's important to know the final drive ratio of the transmission or gearbox in your buggy. Here's a list I have been compiling for a while of various final internal ratios of different buggies. I know I am missing some, so if you know of any that aren't on the list either old or new, feel free to post them and I'll update the master list in this first post.
1.76:1 -- Tamiya Astute
1.86:1 -- Team Pit Stop Chain Drive
1.87:1 -- Team Associated 6-gear RC10
1.87:1 -- Team Pit Stop Chain Drive
1.96:1 -- RPM Stealth RC10 and RC10T Oval Conversion (Grey case)
2.00:1 -- Team Pit Stop Chain Drive (optional)
2.00:1 -- Schumacher Cat 2000 - Cougar 2000 - Storm 2000
2.00:1 -- MIP "Stealth"
2.04:1 -- Schumacher Cat XLS - Pro Cat (Re-release U7236 Pro transmission)
2.07:1 -- Schumacher Top Cat - Cougar (Re-release U7600 pro transmission)
2.10:1 -- Team Losi XXX4
2.14:1 -- Team Pit Stop Chain Drive (optional)
2.14:1 -- Traxxas TRX-1 - TRX-3 - TCP
2.18:1 -- Team Losi JRX2 - JRXT
2.19:1 -- Team Losi Pro SE - XX Buggy
2.20:1 -- Yokomo MR4-BX
2.21:1 -- Kyosho Lazer - Lazer Alpha - ZX-R - Triumph
2.22:1 -- A&L Lethal Weapon
2.25:1 -- Team Associated Stealth RC10 - RC10T - Dual Sport
2.28:1 -- Team Pit Stop Chain Drive (optional)
2.29:1 -- AYK Pro Radiant
2.33:1 -- Yokomo YZ10 - 870C - Works
2.40:1 -- Team Associated B2 - B3 - T3
2.43:1 -- Team Losi XXX CR
2.43:1 -- Schumacher CAT - Top Cat - Bosscat - Cougar - XL (Original or re-release standard transmission)
2.44:1 -- Tamiya DTM + 4WD
2.53:1 -- Schumacher Pro Cat
2.56:1 -- Team Losi XXX BK2 MF2
2.60:1 -- Kyosho RB5
2.60:1 -- Team Associated T2 - GT - B4 - T4 - SC
2.61:1 -- Team Losi XXT - XXT CR
2.65:1 -- RPM Stealth RC10T Conversion (white case)
2.67:1 -- Duratrax Evader SX - BX
2.72:1 -- Schumacher 98/99/Axis
2.72:1 -- Traxxas Stampede - Rustler - Bandit - Blue Eagle - LS - LS-II - SRT
2.90:1 -- TAG Coyote
3.03:1 -- Kyosho Ultima
3.79:1 -- Kyosho Ultima Re-release
(Spur gear teeth/pinion teeth) X transmission ratio = FDR
- Been thanked: 325 times
Re: Transmission Internal Drive Ratios
Kyosho Optima?
- dinglem
- Has thanked: 248 times
- Been thanked: 682 times
AYK Pro Radiant - 2.29
TAG Coyote - 2.90
TAG Coyote - 2.90
- Has thanked: 170 times
- Been thanked: 23 times
- dldiaz
- Has thanked: 41 times
- Been thanked: 58 times
Does anyone know the internal drive ratio for a Kyosho Lazer Alpha?
A knowledgeable person told me 2.21
Elsewhere on RC10Talk, I see where somebody estimated a Lazer ZX would be "something like 2.28"?
-dldiaz
- Has thanked: 1129 times
- Been thanked: 3917 times
I trust Terry, and assuming the pulley teeth are the same as ZX which I can't imagine they would differ then it should be 14/31 so 2.21 and some change
- dldiaz
Great, Thanks!
By The Way - in looking at the transmission ratios in this thread, I came across something I never knew... AE RC10T2 has a 2.6 internal ratio??
Is that right?
That would mean the T3 went back down in ratio to 2.4, then up again to 2.6 in the T4.
-dldiaz
- dldiaz
I see now in the T2 manual that it is a 2.60:1 transmission.
Good to know, as I plan to start on a T2 for vintage racing soon - I have not previously built a T2.
-dldiaz
Yeah T2 was same as GT and pretty much all the modern stuff. Weird how the ratios bounced around but motor tech was always changing I guess
- Has thanked: 665 times
- Been thanked: 473 times
Just checked my Lazer zxr that I’m rebuilding and yes your correct 14/31
2.214:1
- 1151 Views
Last post by templeofspeed
- 2780 Views
Last post by TheDiamondOne
- 414 Views
Last post by fakiee
- 2833 Views
Last post by Lou0151
- 2097 Views
Last post by polarbear
- 1323 Views
Last post by Rattlesnaker
- 3519 Views
Last post by teman
- 1475 Views
Last post by ericsp2
pma1123 and 2 guests
