Extend rear arms
- DMAT
- Been thanked: 4 times
Extend rear arms
was there any form of an extended rear arm for the rc10?
Id like to try running b4 universals in the rear but need like 1/2" extra on each arm vs the stock arms.
- Charlie don't surf
- Has thanked: 357 times
- Been thanked: 470 times
Re: Extend rear arms
I don't usually say this, but use the search feature-
There are 3-5 dozen threads with tons of posts on this subject.
- DMAT
just gonna put it out there but the search filter is frustrating.
It omits half the words i search every time.
Just say i search extend rear arms. it omits rear and arms.
Its gotten to where im just in the tech section going down the pages until i find what I want now.
- Has thanked: 3 times
- Been thanked: 10 times
90% of the info you need is here
http://www.rc10talk.com/viewtopic.php?f=38&t=8848
if your going to run b4 cvds, your going to need to change arms, hub carriers, and b4 need some wheels
yes, it is not a super search engine.
you can go to advanced search in google and type in the text you want to search, and select 'www.rc10talk.com' for the website and it will give you matches without ignoring words.
alternatively the top two threads in this tech section should give you PLENTY of information regarding arms and the various options you can try to use later model parts, b4, b44, etc.
long story short RPM made longer rear 'worlds' arms and intended to have you narrow the chassis. these can be used (though very hard to find), dynotech makes a version for the klein sprint car that are almost identical and what most guys run.
alternatively you can use standard arms, B4 hubs, and B44 cvds with some spacer shenanigans to get what you want. this uses B4 wheels in the rear.
- DMAT
If I ever raced, would this be considered legal?
and yea, on one of scr8p's threads, it went klein arms, b4 carrier, and it should work. still searching on the hinge pins at moment
I really have no plans on which wheels to run. once im in 3/16" theres so many possibilities. I do want to get my talons running again, those were fun.
- 989 Views
Last post by cautrell05
- 22 Replies
- 4596 Views
Last post by mdutcher
- 608 Views
Last post by RC10resto
- 945 Views
Last post by LowClassCC
- 1120 Views
Last post by KidAgain
- 919 Views
- 862 Views
Last post by GJW
- 1171 Views
Last post by Phin
