B2 rear arms
B2 rear arms
Hi guys, can you please enlighten me if the B2/B3 rear arms able to fit into the gold tub rear arm mounts? Thousands thanks!!!
My collections:
Nikko Brat, Nikko Dictator II, Nikko Thunder Eagle, Kyosho Pure Ten Nitro, Associated RC10, Associated RC10T, Associated RC10 Graphite, Associated B4, Tamiya Tamtech 1/24 Porsche 962C, Tamiya Striker, Tamiya TRF 501X WCE.
Re: B2 rear arms
They will fit if you modify the mounts, need to be shortened and have material removed from around the outside. But the car will end up too wide with B3 arms. If you can get B2 arms on it with B3 hub carriers it might be narrow enough.
Re: B2 rear arms
I'm trying to use B2 rear arms with TRF 501X rear carriers (should be the same as B4 or B44 carrier) combination to be able to mount on the B4 wheels instead of acquiring the dynotech arms. Any idea what the width would measure?
By the way, I've read in here that one of the members had utilised Losi XXCR rear arms. Is it a direct fit to the rear arm mounts or material need to be remove to fit?
My collections:
Re: B2 rear arms
Anyone in here tried these?
My collections:
- LowClassCC
- Has thanked: 108 times
- Been thanked: 171 times
Re: B2 rear arms
i used xxxcr front caster blocks and spindles along with xxcr front wheels on mine but not not any rear cr parts.
Re: B2 rear arms
I really wonder why no one tried using B2's arms?
My collections:
Re: B2 rear arms
What is the wide of your front then? Does the xxxcr front arms mount onto the bulk head (narrow or wide??) without any modification?LowClassCC wrote:i used xxxcr front caster blocks and spindles along with xxcr front wheels on mine but not not any rear cr parts.
My collections:
- LowClassCC
Re: B2 rear arms
http://www.rc10talk.com/viewtopic.php?f=35&t=12686
i just used the outermost cr parts, not the arms. car also has the narrow rpm wide arm front. the width is 9.75" which is just under the roar limit of 250mm/9.8425".
- 989 Views
Last post by cautrell05
- 22 Replies
- 4596 Views
Last post by mdutcher
- 608 Views
Last post by RC10resto
- 1120 Views
Last post by KidAgain
- 919 Views
- 862 Views
Last post by GJW
- 857 Views
Last post by DMAT
- 1171 Views
Last post by Phin
