Different Rear Arms?
I'm in the process of restoring 1 "a" chassis rc10 and putting another "b" chassis runner togeather, while doing so I noticed that the arms for the "a" chassis are shorter where the hinge pin goes through and it requires a shorter hinge pin, was there a running design change using the same part#'s for the rear arms or are they different p/n's and if so what p/n goes to which?
Thanks,
Thanks,
- RichieRich
- Has thanked: 39 times
- Been thanked: 25 times
Re: Different Rear Arms?
I believe there was a running change. The newer versions use the shorter pins.
I used shorter 10T pins on mine with the later buggy arms, they're a different part number. Are the short pin arms black? An A chassis car should have the long pin arms standard.
- RC10resto
- Has thanked: 1488 times
- Been thanked: 550 times
Your short pin white arms are correct for a later RC10 CE - and I think they only came on cars with the Stealth trans.
Your A chassis needs standard long pin white arms (fairly easy to find).
- 990 Views
Last post by cautrell05
- 22 Replies
- 4602 Views
Last post by mdutcher
- 947 Views
Last post by LowClassCC
- 1122 Views
Last post by KidAgain
- 919 Views
- 863 Views
Last post by GJW
- 864 Views
Last post by DMAT
- 1171 Views
Last post by Phin
