Bearing size.....yz10 clutch assbly end, etc
OldSkoolRC
Post by OldSkoolRC »
Anybody happen to know the bearing size at the end of the center clutch assbly (also reffered to as the center one way bearing - maybe?) looking at the one at the opposite end of the spur gear. Any help is greatly appreciated.
Also looking for a part number or dimensions on the tiny diff balls that go in the drive outputs.
And last but not least i need a part number and source for the 7mm hex bolts that hold the turn buckles in place top and bottom.
My resto is humming along - cant believe how nice the metal bits clean up with a wire brush and dremel.
Tom
Yokomo 870C, YZ-10, RPM YZ-10, Hot Dog, YR-4 M2, '91 Custom Carbon YZ-10, MR4-BX and some RC10's
crusaderlyf
Re: Bearing size.....yz10 clutch assbly end, etc
Post by crusaderlyf »
The ball bearing in slipper pad is 5x8mm
OldSkoolRC
crusaderlyf wrote:The ball bearing in slipper pad is 5x8mm
Awesome thanks crusader!!
Any chance you know what size the tiny diff balls are in the out drives?
crusaderlyf
sure,thrust balls is 1/16 as many cars.
OldSkoolRC
Thanks again crusader!
Since you really know your yokes, any chance you can direct me to a source for a rear drive belt for the yz10/870c?
Any help is really appreciated.
Tom
Return to “Yokomo Forum”
