B4 hex bearing size
Forum rules
- DMAT
- Been thanked: 4 times
Re: B4 hex bearing size
Assuming your using asc9880 to create a live axle in front. It should be using 3/8 x 3/16 with no flange. I did this conversion on my alloy build but I used a larger bearing for the 1/4" axle.
Id like to see how this goes b/c I've been wondering about this conversion too. The axle I see by jconcepts just looks odd so I've not been sure how it works.
- askbob
Thanks DMAT, that is the part I'm using. I'm not able to test fit the parts right now and wanted to confirm the size since I noticed Acer has a good discount right now.
- Bottom Feeder
- Has thanked: 13 times
- Been thanked: 24 times
Just to mention it in case it's not obvious, the bearings for the hex conversion are the same size as the 'old-style' bearing-in-wheel design. No need to buy new ones.
- 1102 Views
Last post by highwayracer
- 696 Views
Last post by upforit365
- 477 Views
Last post by Mad Racer
- 697 Views
Last post by caesar
- 857 Views
Last post by Stumpy
- 595 Views
Last post by amx73
- 1382 Views
Last post by limestang
- 830 Views
Last post by SMOKE-DOG
