Replacement options for slipper clutch thrust bearing
jbmeyer13
Has thanked: 25 times
Been thanked: 11 times
Post by jbmeyer13 »
While servicing my V1 slipper clutch the thrust bearing which sits between lock nut and spring lost its bearings. I can’t find the original part for sale anywhere (asc 6586) or the replacement (6594) and I’m wondering if there are any suitable work around options. I’m wondering if using a thrust bearing washer from a diff assembly might work comparable. Thoughts?
bluewormx
Has thanked: 41 times
Been thanked: 91 times
Re: Replacement options for slipper clutch thrust bearing
Post by bluewormx »
The Schumacher Thrust bearing for RERE cat xls (part U7216) diff will almost definitely work. amain is back ordered but they have the measurements on there: 1/8 x 5/16 x 9/64".
jbmeyer13
Post by jbmeyer13 »
Thx! Just placed an order so at least I’ll have it back up and running while I try to piece together a V2z
Has thanked: 268 times
Been thanked: 2094 times
bluewormx wrote: Wed Aug 26, 2020 1:05 pm The Schumacher Thrust bearing for RERE cat xls (part U7216) diff will almost definitely work. amain is back ordered but they have the measurements on there: 1/8 x 5/16 x 9/64".
I have a spare 6594 set in front of me. The bronze bushing matches those measurements.
Bringing an old thread back up, and thought I'd throw out a couple options I'd found.
1st. Fast Eddy 3X8X3.5 (F3-8M) bearing. Luckily I ordered two sets to try, because only one outer race from each fit. I tried drilling the race but they are hardened. (These were cheap and I needed to spend a few more dollars to get free shipping).
2nd. I also picked up a bushing for a Dutatrax Evader (9305). It was easy to open up to 1/8" id. After reaming it, it fits identical to the AE 6594.
Users browsing this forum: No User AvatarAhrefs [Bot], No User AvatarBing [Bot], No User AvatarDotNetDotCom.org [Bot] and 4 guests
