RC500 Large Rear Bearing Size?
- limestang
- Has thanked: 100 times
- Been thanked: 249 times
Hoping someone can help. I need the bearing dimensions for the RC500 Rear bulkhead (large size)? I believe the Associated part number is 5256.
Thanks, Limestang
Thanks, Limestang
- a01butal
- Has thanked: 34 times
- Been thanked: 40 times
Re: RC500 Large Rear Bearing Size?
Looks like they could be 30mm x 17mm metric instead of what I originally thought.
This is all very interesting!
- limestang
Turns out this is an odd size bearing and difficult to find. I decided to machine a pair of aluminum spacers to allow use of the easier to source bearings. I will post a photo tomorrow in case someone else encounters a similar problem.
- Limestang
- Limestang
- limestang
Here is the photo. The white bulkhead uses the machined aluminum spacer. I sized for a light press fit.
-limestang
-limestang
- 537 Views
Last post by slotcarrod
- 2290 Views
Last post by Zipster
- 809 Views
Last post by Bottom Feeder
- 502 Views
Last post by Mad Racer
- 708 Views
Last post by caesar
- 879 Views
Last post by Stumpy
- 606 Views
Last post by amx73
- 1036 Views
Last post by OldSkoolRC
