RC10 3s lipo battery fitment?
PTModIT
Post by PTModIT »
That will fit the original RC10 with no mods to the cups or any mods for that matter? I can't seem to find any with a 134mm length.
Thanks
kaiser
Re: RC10 3s lipo battery fitment?
Post by kaiser »
i've got some soft pack turnigy 3000's that fit fine.
that said 3s is insane. :lol: i did it once in a 2wd buggy, wayyyy too much power. undriveable.
slapshot1979
Post by slapshot1979 »
kaiser wrote:that said 3s is insane. :lol: i did it once in a 2wd buggy, wayyyy too much power. undriveable.
:lol: I guess so :lol: my 22 with a 5700kv geared up on 2s is undrivable too me :shock:
PTModIT
Post by PTModIT »
Are there any 2s lipos that will fit side to side without the battery cups?
kaiser
Post by kaiser »
turnigy 4000 hard cases can squeeze in there, but your best bet is to ditch the front cup and get something like a pure tech battery strap, it's still a squeeze but it's better.
side to side without cups the 4000 turnigy's should fit fine, i'll try tonight and let you know.
PTModIT
Post by PTModIT »
I checked that battery on ebay and the dimensions are right but I'm not paying $30+ to have it shipped.
PTModIT
Post by PTModIT »
kaiser
Post by kaiser »
hobbyking.com has them in stock and ship from the us warehouse.
when on their site make sure you choose a location.
PTModIT
Post by PTModIT »
Has thanked: 3699 times
Been thanked: 1980 times
I believe this will fit for much less. Check my dims though because I'm pretty dim myself... :oops:
http://www.hobbypartz.com/83p-2650mah-2s1p-74-40c.html
EDIT: That's the 2s, but I'm quite sure they make a 3s that will fit in that same pack. I'm too lazy to find it so I'll leave it to you. :lol: You'll find a 3s on that site that will fit for much less though. :wink:
Lowgear
Has thanked: 121 times
Been thanked: 795 times
Post by Lowgear »
http://www.rc10talk.com/viewtopic.php?f=35&t=18028
I'd just cut the back off the battery cup. At least that way you don't have to wreck the chassis by drilling holes in it. Then just use a piece of double sided tape or Velcro in the cup to keep the battery from sliding forward. You can also glue a piece of foam to the servo post to prevent the battery from moving forward instead.
PTModIT
Post by PTModIT »
I ordered the Venom battery above.It will fit perfect at 133mm and it's a 3s.I might have to cut the battery cup where it rests against the tub.
soniccj5
Post by soniccj5 »
Just curious, what ESC/Motor setup do you have? I now mine with a 10.5 and a 2s is crazy fast, cannot wait to hear a report once you take a test run with the 3s.
Note: Do not plug in a 3s LiPo balance plug if you still have a 2s wired and plugged in. Unless you want some extra smoke in your work area. :oops:
ED
PTModIT
Post by PTModIT »
CC Mamba Max Pro 5700
PTModIT wrote:CC Mamba Max Pro 5700
Make sure you kiss your RC10 good-bye before you take it on it's first pass. :wink: It will either melt or be demolished on impact... possibly both. It's just too much for that light of a car. It is fun for a split second though. :lol:
