Old ESC with Lipo battery
- Momo5
I've been looking for an old school Tekin 410K esc for a while now and finally found one. I just realized that all I have are lipo batteries. Is there anything I can buy, like something that would go between the esc and battery that would give me low voltage cutoff?
- Lonestar
- Has thanked: 623 times
- Been thanked: 171 times
Re: Old ESC with Lipo battery
Hey Momo
check my last post on that thread's 1st page - it could save you $20-sthing
http://www.rc10talk.com/viewtopic.php?f=35&t=22454&hilit=cutoff
Cutoff doesn't hurt anyway
Paul
Paul
- 8rad
- Has thanked: 9 times
- Been thanked: 38 times
Try the Hobbywing one. As long as you dont mind buying Chinese. They can be had for 10 bucks if you shop around.
Sure beats 25 if you have lots of cars.
http://www.nitrorcx.com/hobby-wing-lipo-battery-protector-for-car.html
- Been thanked: 4 times
I use a low voltage alarm. It doesn't lower or kill power to the car. All it does is start beeping very loudly when the voltage gets too low. There is no problem hearing it. I got it for $5 but at this point we're really penny pinching!
- slotcarrod
- Been thanked: 45 times
I run lipo's with all my old esc's. No problem! As long as you stop running as soon as you notice a voltage drop, you will be fine. I have never seen any of my packs under 6 volts. With lipo's 3 volts per cell is your lower voltage limit! 2 cell 7.4v pack = 6 volts, 3 cell 11.1 = 9 volts.
If you ever go below that and your charger will no longer charge it! You quickly charge the lipo in nimh mode for 1 minute to bring the voltage back up to 6 volts and then switch back to lipo mode on the charger! This method works if you catch the low voltage mistake right away!
Rod Littau
- 4837 Views
Last post by longboardnj
- 2069 Views
Last post by SoloGraphix
- 1031 Views
- 2164 Views
Last post by Brandon G
- 3826 Views
Last post by edwin pibal
- 19 Replies
- 2589 Views
Last post by Lonestar
- 2120 Views
Last post by sundevil67
- 1009 Views
Last post by Flargen
