Houge steering question?
General info, Q&A.
TAP
Post by TAP »
I picked a set up on E-bay and when they came they looked like they've been under water for a long time :twisted: ... the bearings are rusted solid!!! I need to know what size the bearings are so I can hit the hobby shop for a new set?
Re: Houge steering question?
1/4 x 3/8 flanged.
TAP
Post by TAP »
Thanks Bro!!!! :)
TAP
Post by TAP »
OK , I've got the bearings, and have installed the black thingies in them, now how do I mount them to the chassis?????
Has thanked: 357 times
Been thanked: 470 times
TAP wrote:OK , I've got the bearings, and have installed the black thingies in them, now how do I mount them to the chassis?????
You sandwich the steering between the chassis with a screw- :lol:
TAP
Post by TAP »
Ha! Ha! Charlie... I need the right screws, they didn't come with the set.
Phin
Has thanked: 87 times
Been thanked: 248 times
Post by Phin »
They should use the same 8-32 screws that mount the stock RC10 servo saver.
From: http://www.rc10talk.com/viewtopic.php?f=35&t=19119&start=15
did you get the shoulder nuts with the bellcranks? (in the picture above, its the black nut on top). It's a shoulder nut that is threaded for #8-32 screws and OD of 1/4" for the bearings/bushings.
check out the manual for the worlds car, which uses a very similar setup:
http://www.teamassociated.com/pdf/cars_and_trucks/RC10/Worlds_Car/WorldsCar_manuala.pdf
TAP
Post by TAP »
Thanks for the info guys, I got the nuts with the bellcranks, just thought that I needed screws like the DS has???
