steering install question
sk7
Post by sk7 »
i picked up a gold tub rc10 locally and also got a graphite chassis with it, i am trying to switch evrything over to the graphite chassis . When i put the steering arms in i noticed the threaded ball ends come real close to the chassis is the install right i have took a picture, i wonder if the washer is enough.
thanks Brandon
MelvinsArmy
Been thanked: 11 times
Post by MelvinsArmy »
You could shave down the ball end threads with a Dremel. I had a car with the same problem.
when your using the stock bellcrank on a graphite chassis, you need to use an 8/32 nut under the bellcrank, to actually tighten the screw to the chassis first. the nut is taller than the washer, and should solve your clearance issue.
http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LX3066&P=0
Users browsing this forum: No User AvatarGoogle [Bot] and 3 guests
