cvd's and top shaft for rc10
- Regular Member
Will the b44 cvd's work in the rc10? What is needed, well other than a b4 top shaft in origanal stealth tranny?
Thx
Thx
- 8rad
- Has thanked: 9 times
- Been thanked: 38 times
Re: cvd's and top shaft for rc10
The b44 CVD's will not work without longer arms and new hub carriers. The B4 top shaft is only needed to mount the B4 slipper assembly.
For most applications the stock stealth slipper is fine.
- Regular Member
- 8rad
- JK Racing
- Has thanked: 139 times
- Been thanked: 246 times
b44 rear cvd's will work with stock rear arms, but you must use b4 rear hubs. on the b4 hubs, you must drill out the hinge pin hole to 1/8"
to use the b4 top shaft, you just need all the b4 slipper parts and drop it right into the stealth gearbox, no issues.
- 830 Views
Last post by slow_jun
- 24 Replies
- 4924 Views
Last post by JosephS
- 2110 Views
Last post by Chillout47
- 1085 Views
- 1538 Views
Last post by 68sportcoup
- 1032 Views
Last post by ljh501
- 2033 Views
Last post by CrazyRC
- 890 Views
Last post by askbob
Bing [Bot] and 8 guests
