b4 top shaft question
farmer
Post by farmer »
ok im sorry if this has been answered but i cant find it
but what size bearing is needed for the long side of a b4 top shaft
3/8 x ?
i know that the gear side is 3/8 x 3/16
but the long side is thicker
im trying to get this in my MIP change box
also when i look at the specs online
wich is no help
why does it need a shaft spacer?
any help
thx farmer
farmer
Re: b4 top shaft question
Post by farmer »
nvm
thx farmer
Hakase
Post by Hakase »
I have original stealth casing in my rc10ce, and b4 topshaft _without_ spacer. Using same sized bearing on both sides and fits fine. Maybe you should get topshaft without spacer?
askbob
Post by askbob »
Not sure on the mip, but using the B4 topshaft in the 2.25, you don't use the spacer. Same bearing size on both sides.
Users browsing this forum: No User AvatarAmazon [Bot] and 2 guests
