B4 Top shaft
Forum rules
HarlowS
B4 Top shaft
Post by HarlowS »
After some help to save my sanity. I found this Steel topshaft at home and cant work out what its for, The best guess i have is that its an aftermarket B4 top shaft ??? As its the same length also. However, it has a thicker shoulder up to the gear that doesnt fit the standard B4 bearings.
So, is it an after market B4 shaft like the MIP one, and if so did it use different bearings in the gearbox case for it ???
Many thanks in advance.
HarlowS
Re: B4 Top shaft
Post by HarlowS »
Ignore me, sussed it now....... :)
JosephS
Has thanked: 1243 times
Been thanked: 639 times
Re: B4 Top shaft
Post by JosephS »
HarlowS wrote: Mon Jan 11, 2021 4:19 pm Ignore me, sussed it now....... :)
Wait what was it?
RC10th
Has thanked: 52 times
Been thanked: 1548 times
Re: B4 Top shaft
Post by RC10th »
JosephS wrote: Wed Sep 29, 2021 5:52 pm
Wait what was it?
Probably something to do with the machined "spacer" instead of a bearing surface
JosephS
Re: B4 Top shaft
Post by JosephS »
RC10th wrote: Wed Sep 29, 2021 11:31 pm
Wait what was it?
Does it use a different bearing for the shaft?
