Toe-in degrees?
General info, Q&A.
86NESKid
Toe-in degrees?
Post by 86NESKid »
can someone give me a brief synopsis of what the differences are in 0 degree and 3 degree on the rear mounts.
which is better for what?
Has thanked: 359 times
Been thanked: 470 times
Re: Toe-in degrees?
The zero's were pretty much used on oval and on road, the 1.5's and 3 deg were off road use, generally the 10 and 10t is most consistent with the 3 deg mounts and zero deg hub carriers.
86NESKid
Re: Toe-in degrees?
Post by 86NESKid »
Awesome response.
Thanks!
