Help, need info on converting my rc10t to brushless
- Regular Member
Ok this is my first post. I acquired a rc10t back in 1992. My wife was quick to take it as hers because of the fun factor. So here it is almost 20 years later and my wife and I got bit by the rc bug again. Well the tech has changed and we quickly relised a upgrade was needed to get our or should I say her rc10t rolling again.
For christmas I would like to get her eveything she needs to change over to brushless. Ok so where do I start? What do I need? What brushless combo should I run? No racing just playing around and fun on a local track so a waterproof system would be nice. What hop ups do I need to get? ect.
Thanks for any info you have.
Crazydeath
Crazydeath
- Regular Member
Re: Help, need info on converting my rc10t to brushless
Ok did some research and I think I am figureing out what I need.
Dose anyone here see anything wrong with this esc combo?
http://www.hobbypartz.com/car.html
Also I will upgrade the tranny to rpm and rebuild it with new bearings and stuff. I thought about hopping my drive shafts to 3/16". Mabey new cvc mounts also.
Any input would be awsome.
Thanks
Thanks
- Charlie don't surf
- Has thanked: 356 times
- Been thanked: 470 times
That combo looks good, remember that AE has never changed the offset of their truck rims, so any 3/16 rim will work. Watch batteries over 5000mah as they are sometimes too large to fit in the bulkhead cup
- Regular Member
Charlie don't surf wrote:That combo looks good, remember that AE has never changed the offset of their truck rims, so any 3/16 rim will work. Watch batteries over 5000mah as they are sometimes too large to fit in the bulkhead cup
Ya I saw that the 5000mah were too big. I was thinking mabey a 3s lipo 2000mah would fit fine. I do not know what the runtime would be. And if i decided to go 5000mah i have access to a machine shop so I would just have a new bulkhead cup made up out of aluminum if needed.
I was also looking at the traxxas esc combo because of the water proof factor. Any thoughts on that?
check this thread made probably almost the same time you started yours:
http://www.rc10talk.com/viewtopic.php?f=36&t=24536
- Regular Member
jwscab wrote:check this thread made probably almost the same time you started yours:
Yep I read it, that is how I learned about the battery. I was after alot of input on all the options i had so I made this thread.
- klavy69
- Moderator
- Has thanked: 639 times
- Been thanked: 294 times
They are decent for a runner but the only thing that people get carried away with is that while the electronics are waterproof...the rest of the buggy isn't. Unless you plan on running thru water or underwater the waterproof stuff isn't really needed. I have a few sets and have done alot of water running but got tired of bearings falling apart and the maintenance of it all so they don't get too wet any moreCrazydeath wrote:I was also looking at the traxxas esc combo because of the water proof factor. Any thoughts on that?
- Regular Member
Well I don't plan on running it through water that much if at all. The thing is wintertime in western Oregon is very rainy. The roads and gravle dry out between storms for the most part but the dirt and grass is always wet. I just was worried about that. I will try my best to keep from running on the wet stuff but there is always that oops factor.
There is a Mamba pro system I have been looking at also. A littel more money for it but I'm not sure it's worth the extra money.
- RC104ever
Here is my 2 pennies:
I have a Mamba Max Pro and it has been great. Yes, its a bit more than the Hobbypartz stuff, but its not quite as much as other brands either. Gives you good software which you can tailor brake / throttle curves and other stuff and it comes with a code to order a free Castle Link so you can hook up the ESC to your computer. Software is a free download from the Castle site. I have a 4600kv setup and just switched to a 4 pole 5700 kv which is, to put it mildly, 'stupid fast' on 2s lipo.
I am also running a 5000 mah GensAce 2S lipo, which I did get from Hobbypartz and it *just* fits into the rear bulkhead if you get the hard case lipo. Actually, it stretches the bulkhead just a tiny bit. You won't be able to use the original battery cups unless you cut the front off it. I use the B44 battery posts with the threaded rods and round thumb screws, and then use the stock battery strap.
The other thing I use which works great is the Fly Sky GT3B radio and receiver which was only $35 at Hobbypartz.com An excellent bargain radio which works very well.
Hope that helps, good luck!
I
I
- Chris
Lots of cars...so many cars
- Regular Member
RC104ever wrote:Here is my 2 pennies:
I
Yes this info helps alot. Can you post pics please? The radio is no problem. I own 6 traxxas nitro trucks with 2.4 radio so I will just get anouther traxxas reciver and hi touque servo.
I think I'm going to go with that mamba max pro set up you talked about.
Thanks again for that great info.
- RC104ever
No problem - I will try and snap some pics today
- Chris
- RC104ever
Okay, so here are some pics of my RC10 with the above gear. Well, except the Fly Sky system, which I've moved to my RC18B.
Gens Ace 5000 mah 2S lipo and Castle Mamba Max Pro
Castle 5700 kv brushless with 23 tooth pinion and 81 tooth spur
- Chris
What are you using for a rear battery mount? I have those same battery packs and they don't fit into the stock RC10T rear battery mount, and I'm hesitant to cut the top of the mount off.
- RC104ever
It's a stock rc10 rear bulkhead but it does take a bit of pushing to get it in there. It will stretch the bulkhead a very little bit but it's nothing major.
- Chris
- 1030 Views
Last post by 8rad
- 1539 Views
Last post by 2500M_Sub
- 986 Views
Last post by MelvinsArmy
- 1186 Views
Last post by Daryl Lane
- 1515 Views
Last post by Jschoenb
- 808 Views
Last post by Bugle
- 1861 Views
Last post by hano5446
- 1614 Views
Last post by Jack Smash
Users browsing this forum: Bing [Bot] and 4 guests
