Brushless RC10t?
Jschoenb
Brushless RC10t?
Post by Jschoenb »
I've been thinking about going brushless for my RC10t basher. I was just wondering if the stealth tranny can handle it. Any thoughts or suggestions?
Thanks
carloco8
Has thanked: 74 times
Been thanked: 271 times
Re: Brushless RC10t?
Post by carloco8 »
Stealth tranny, yes. 6-gear transmission, not preferable. Stick with a 7.5 or higher though, lower turn brushless tend to overstress the small slipper and diff (in comparison to the modern cars that they were designed for).
saucisse
Post by saucisse »
I'll go brushless with my 10T project but I have all metal gears (MIP tranny)
From the past I can tell you that if you don't adjust correctly your diff (if it slips too much) your gonna fry the diff gear in 5 min or less :shock: ...been there, done that :roll:
I don't suffer from insanity, I enjoy every minute of it!!
Daddeo
Post by Daddeo »
I ran a Mamba Max 7700 system in my runner 10T for awhile. Initially the only damage was a bent CVD axle, secondary damage was only minor wear to the diff gear and balls. Just as saucisse said, adjust your diff appropriately or failure is imminent!
Jschoenb
Post by Jschoenb »
Thanks, couple more questions though. What do you mean by 7.5 or higher and also how do you adjust the differential?
shodog
Been thanked: 91 times
Post by shodog »
Basically you have to crank down hard on the diff screw to the point where you barely has any diff action. if it's too loose, the diff will slip so much and cause so much heat that the gear will melt. This is the reason why traxxas has all steel gears in their new brushless versions.
Tadracket
Post by Tadracket »
Jschoenb wrote:.....What do you mean by 7.5 or higher....
That is the number of turns. The lower the number the more the power. Plus the shorter the battery life. Keep it @ 7.5 turns or more and you'll save your drive train and improve run times.
He's an idiot. Comes from upbringing. His parents are probably idiots too.
Jschoenb
Post by Jschoenb »
Thanks for the info.
Return to “RC10 Truck Forum”
Users browsing this forum: No User AvatarAhrefs [Bot] and 3 guests
