Brushless RC10T
Brushless RC10T
Found my old RC10T while moving and need some help to turn this thing into a beach basher with a Novak ss5800
system I had lying around, how can I beef up my drive train? lookink for bearings troughout my truck, what can I do?
- Has thanked: 51 times
- Been thanked: 108 times
My BL RC10T..
Hi hano5446,
in THIS THREAD I've posted my BL RC10T. The drivetrain is pretty bulletproof, consider buying the best (ceramic) Diff balls U can get. Of couse berrings are a MUST!
I know you'll love it.....
Chewie.
Chewie.
*** POWDER - KING ***
- Asso_man!
- Has thanked: 40 times
- Been thanked: 82 times
I think he was talking about a vintage rc10t whereas you are talking about a T4, its youngest son...
Come and visit the stable
i got an rc10t with a novak ss5800 setup in it. the truck is a stock #7001 with the bearings. if i tighten up the slipper on the stealth it will cartwheel over with an 87 tooth spur and an 18 tooth pinion. only thing i have replaced has been the spur gear 'cause the motor got loose and burned off all the tooth tips. the dogbone hub ends are getting worn so i will probably do soon and recommend a cvd conversion. other than that just periodically take the stealth apart and lube it and keep it clean. i run about 2 packs every other day through it since i put the 5800 in it a few months ago and ran countless packs through it way back when. heres some pics of how a beater should look
Mahalo!!!!!!
Thanks everyone I hope to take it to the beach here in Hawaii by next weekend equiped with paddles
MAHALO!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
- 809 Views
Last post by Bugle
- 1515 Views
Last post by Jschoenb
- 2630 Views
Last post by GarySmith
- 838 Views
Last post by acerpower1
- 1147 Views
Last post by tuna.Rc
- 5970 Views
Last post by Crazydeath
- 3371 Views
- 2076 Views
Last post by Gold shocks
