Removing glue from aluminum wheels
I know it's hard to believe anyone would do it but I have a nice set of aluminum wheels that have been glued to the tires. I'd like to save the tires if I can and I know acetone will melt the glue. My question is if the acetone will harm the aluminum? Does anyone have experience with this?
Gary
Re: Removing glue from aluminum wheels
acetone should not hard the wheels unless they have some type of clear coating applied.
acetone is usually used as a pre-cleaner for tig welding aluminum.
- MelvinsArmy
- Been thanked: 11 times
CA glued to the wheels? If so, try putting them in the freezer for a few hours. Depending on the quality and age of the glue, it could make it brittle and the tires might be easily removed. Worth a shot, it's not going to hurt anything. Well, except hopefully the glue.
- CamplinP
Have you tried CA debonder. I have never tried it on aluminum but it is safe for your fingers. Works great on all the stuff I have tried it on.
Hadn't thought about the freezer, thanks Melvin I will give it a go. It seems like CA but there's so much of it.
I read online somewhere that CA debonder is usually made from mostly acetone.
Gary
- 1830 Views
- 21795 Views
Last post by 328isjohn
- 3280 Views
Last post by Jim85IROC
- 1084 Views
Last post by rc10johnny
- 2581 Views
- 844 Views
Last post by markt311
- 1113 Views
Last post by LowClassCC
- 1493 Views
Last post by 59burst
Users browsing this forum: Amazon [Bot] and 6 guests
